Old 03-03-2008, 08:35 PM
jpatricio_76 is on a distinguished road
cn1 pin assignment
Hi! can anyone help me where to find a link or manual that could show the pin assignment of cn1 of a fanuc velocity control, type: A06B-6050-H104 with control card or top pcb number A20B-1000-0560.
Jpatricio
Old 03-04-2008, 08:39 AM
fanuservicetech is on a distinguished road
This information is in Fanuc AC servo Unit Maintenance manual B-54765E. You can call Fanuc America at 18883268287 to purchase it.
A quick description of pin out for CN1 is
1 PRDY1
2 ENBL1
3 OVL1
4 VRDY1
5 CURR
6 --
7 VCMD
8 *ALM1
9 *ALM2
10 *ALM4
11 *ALM8
12 --
13 COM
14 PRDY2
15 ENBL2
16 OVL2
17 VRDY2
18 CLMT
19 --
20 E
Old 03-04-2008, 10:07 PM
fanucservicetech,
Thanks sir for the information. I just want to ask further questions. Where can I connect if I want to input PWMA,*PWMA, PWMB, *PWMB signals? Because I want the motor to rotate forward and reverse, what terminals should I use and what signal do I need to input?
Once again, thank you very much.
James_76
Old 03-04-2008, 10:19 PM
where to connect
fanucservicetech,
Thanks for the information. I just want to ask further questions. Where can I connect if I want to input PWMA, *PWMA, PWMB, *PWMB signals? IF I want the motor to rotate reverse-forward, what terminals should I use and what signals do I need to input?
Once again thank you very much.
james_76
Old 03-04-2008, 10:42 PM
This is an analog AC servo. Basically it typically receives analog +/-10VDC at VCMD (pin 7) in reference to COM (pin 13). it generates the PWM signal on board. Direction is controlled by +/- and voltage level is for speed.
Old 03-05-2008, 02:24 AM
fanuc ac servo
fanucservicetech,
Sir, do you mean I just have to connect the -10/+10vdc signal on 7(+) and 13(-). And its rotation, forward maximum frequency at +10vdc and reverse maximum frequency at -10vdc?
Thanks again sir.
james_76
Old 03-05-2008, 07:21 PM
MANUAL PULSE GENERATOR OR HANDLE
fanucservicetech,
Sir, how about if i would include a manual pulse generator or handle, where should i connect also?
Thanks again.
jpatricio_76
Old 03-06-2008, 07:35 AM
Originally Posted by jpatricio_76 View Post
fanucservicetech,
Thanks again sir.
james_76
Yes. that's correct
Old 03-06-2008, 07:38 AM
fanucservicetech,
Thanks again.
jpatricio_76
Sorry, I have no idea on this question. In a typical application, manual pulse generator and handle signals are connected to CNC and CNC would inturn send out VCMD signal to servo unit.
Old 03-06-2008, 05:22 PM
fanucservicetech,
Sir, thanks a lot for the information. It would surely help me a lot.
Thanks again.
jpatricio_76
  #11   Ban this user!
Old 03-09-2008, 11:05 PM
fanucservicetech,
Sir, I saw a connection from my machine, pin 7 (vcmd) for positive and pin 20 (E) for negative. It's not using pin 13 (com) for negative. When should I use the pin 13?
Thanks again.
jpatricio_76
  #12   Ban this user!
Old 03-23-2008, 09:53 PM
fanucservicetech,
Sir, I'm sorry to disturb you once again but I have one more question... I already connected the control signal for cn1 and it runs smoothly for forward direction but when I reverse the direction of the motor, I could hear some unusual sounds from the motor itself wen I reverse it in low frequency, supplying -17mVdc. I wonder if I have mistakes in the connection of encoder. I can't check it either because I also do not have pin assignment for the encoder of A20B-1000-0560.
Doing year 10 Assignment.. DMartello Australia, New Zealand Club house 8 05-03-2006 05:41 PM
