It should work. Does a different card work in your 0iTC?
I have seen problems with the PCMCIA connectors in the Fanuc controls failing, even had to have two of them replaced at customer's shops after they quit working.
FRIENDS,
RECENTLY WE HAVE COPIED THE PART PROGRAMMES IN A PCMCIA CARD IN ONE OF OUR MACHINE WITH 0iTB CONTROL AND WE WANTED TO COPY/TRANSFER THE PROGRAMMES IN A DIFFERENT MACHINE WITH 0iTC CONTROL. WE HAVE CROSS CHECKED ALL THE PARAMETERS RELATED TO PCMCIA CARD AND FOUND OK.
THE PROBLEM IS WE ARE GETIING MEMORY CARD FORMAT ERROR IN THE MACHINE WITH 0iTC CONTROL WHEN WE USE THE SAME CARD AGAIN IN THE MACHINE WITH 0iTB CONTROL IT IS WORKING.
IS IT NOT POSSIBLE TO USE THE SAME PCMCIA CARD IN TWO DIFFERENT MACHINES FOR TRANSFERRING MACHINING PROGRAMMES.
REGARDS,
CHANDRU
YOU WILL CARD İS FORMATED..
FAT32 OR
FAT
