Old 02-14-2008, 07:17 AM
mr_electrician is on a distinguished road
Flashing bit
Hi, I am learning how to use our LADDER III software. I am writting a small program and I need a .5s flashing bit. Where would I find this 0.5second flash bit for Fanuc. Also, how to you set the preset time of a timer? For example I am using a SUB 3 timer.
Old 02-14-2008, 08:06 AM
codyst is on a distinguished road
Sub3 timers are set in the PMCPRM page under TMR. Sub24 timers are "fixed" timers in the sense that you have to physically edit the ladder to change the timers preset.
If you're trying to get a bit to flash to do something like a red stack light flash you can do whatever bit you're using to activate the output and run it through a timer, and have the output reset its self. It would look something like this.
Flashon--SLRED------------------------------ SLRED
I I--------I/I----------Sub3 TMR1---------------O
I had to put the dashes between my comments because the post kept auto formatting to the left margin.
Old 02-14-2008, 08:20 AM
My example is wrong. That would essentially turn the stack light on for about a milisecond, and then shut it off for the timer's preset. The correct way would be
Flashon-------SLRESET-------------SLRED
---I I-----------I/I-----SUB3 TMR1---O---This line is the amount of off time.
SLRED--------------------------SLRESET
--I I----------Sub3TMR2-------------O---This line is the amount of on time.
Old 02-15-2008, 01:19 PM
f-bu is on a distinguished road
R9091.0 LOG0 always 0
R9091.1 LOG1 always 1
R9091.5 CLK02S clock 200ms period
R9091.6 CLK1S clock 1s period
ready made clocks are provided also
