Old 02-14-2008, 04:17 AM
davider is on a distinguished road
Cycle Start output on Fanuc 15-MA
Hi, I would like to detected with an electronic module when the NC is running. In a lot of Fanuc based machines there is a "Cycle Start" button with a lamp that is on when the NC is running.
Unfortunately on this machine this lamp is not present. I would like to know if the Fanuc 15-MA controller always provide a "Cycle Start" lamp output or this is specific to the machine builder choice.
Is there another way to detect the NC is running?
Thank you for your help!
Old 02-14-2008, 08:17 AM
I found a Fanuc 15 manual and it talks about the status outputs:
- 29.6 Automatic operation start lamp signal: "This signal is sent out when automatic operation is being activated."
So it seems this signal should present by default on the controller. So anybody as an idea where I can found this signal?
The machine I'm working on is a Moore G4139.
Old 02-14-2008, 08:30 AM
codyst is on a distinguished road
This is a signal internal to the controller that can be used by the PMC. If you're wanting to put a cycle light on the machine you would have to edit the ladder using this signal and tie it into a physical output to power the light.
Old 02-14-2008, 09:18 AM
Hi codyst. Thank you for the fast answer. I'm a newbie on Fanuc, could you please explain a little bit further about the ladder editing? I tried to search in the forum but I didn't found something useful (or at least I think)
By the way on a maintenance manual there is a reference about a STL signal (cycle start lamp signal) on the control unit PCB (A20B-1003-2040. There is a jumper to set common or 24V output for STL, SPL, ecc... signal.
So my question: are we sure there isn't already a signal on the main controller unit for the cycle start?
I'm going in the wrong direction? Please help...
Cycle start not working - SL3B andy.f Mori lathes 10 02-15-2008 12:30 PM
Canned cycle output in Gibbs lathe naytep GibbsCAM 2 08-30-2007 02:38 PM
Remote cycle start REVCAM_Bob Fanuc 6 03-18-2007 07:08 PM
Remote cycle start? REVCAM_Bob Fanuc 0 01-20-2007 10:59 AM
Cycle Start button kaleem1 Mach Software (ArtSoft software) 7 12-24-2005 02:05 PM
