Old 02-12-2008, 01:46 PM
tkea is on a distinguished road
Tornado 200 Fanuc ot not responding spindle and turret
Hi, i have a big problem. I bought lathe tornado 200 with no backup baterry. I upload all parameters, zeroes, but i'm not sure with params 900 - 940, i copied it from similar machine, which has a barfeeder.. When type in MDI T1 M6, CycleStart button still lighting, but response of machine is NOTHING. The same, when i try rotating turret by hand. When i type S200 M3, the spindle still stop and on spindle inverter LED's lighting "--".
Old 02-12-2008, 04:34 PM
GPena is on a distinguished road
If this is a lathe, for the tool change you need to write T0101; M06 is for mach. centers.
GP.
Old 02-12-2008, 09:43 PM
Dave1's Avatar
Dave1 is on a distinguished road
Did you put the diagnostic or "pc" parameters back in? If not it won't run like it should (ask me how I know that!) They are numbers 300-549 on the diagnostic page.
Parameters 900-940 are the ones that tell the control how many options and basic functions you get.
The spindle won't start unless the chuck is clamped.
Dave
Schneider Machine
A force of one
Old 02-13-2008, 05:00 AM
Dave
And where i get this Diag params?
Old 02-14-2008, 03:11 AM
Dave1's Avatar
You have to find a lathe just like yours or get a hold of a dealer that sells or sold tornado lathes. The diag parameters control all the switches that run the lathe. If you can save to a pc that would tell you if they are there. Put the control in edit, push the diag/parameter button, might have to push it twice, it should say diagnostic in the upper right hand corner of the screen, then push output and it will send them to the pc. Look at the file, the number you will see are 10300-10549. If they come up with all zero's then they are missing.
I just went through this on my Takisawa with a Fanuc 0T, I was able to get them from the Takisawa dealer, thay had them on file thank goodness.
Good luck,
Dave
Schneider Machine
A force of one
Old 02-14-2008, 03:30 AM
Dave1's Avatar
I would email this company, maybe they have them or can send you in the right direction.
http://www.machinery.co.uk/directory...-Lathe-Co.aspx
Dave
Schneider Machine
A force of one
Old 02-14-2008, 03:44 PM
rrbmachining's Avatar
rrbmachining is on a distinguished road
I have a tornado 200 and if you supply an email address i will see if i can send you a full set of parameters when i get to the shop in the morning if thats any use to you
regards
Richard
RRb Machining Services ltd
Old 01-27-2011, 09:49 PM
tushar is on a distinguished road
can you pl help me tornado 200 parameters & dgn
thanks in advance
tushar
Old 04-19-2011, 04:44 PM
lesr is on a distinguished road
Don't know if this was resolved, I'm ex 600 Lathes if anyone needs help
Les Robbins CNC Services - Index
Old 05-21-2012, 11:55 AM
Kamal B is on a distinguished road
Did you get the Parameter & dgn. DO you have the operator manual.. I am stuck with a Torado 200 and no one is ready to take up maintainence due to unavailability of manuals.
if you could pls hlp.
Kamal
  #11   Ban this user!
Old 05-21-2012, 12:29 PM
Kamal
what is the machine serial number ?
regards
Les Robbins
EditComm - CNC communication software - Les Robbins CNC Services
Colchester Tornado Fanuc 21i-t Stebedeff Fanuc 2 11-07-2010 07:43 PM
Colchester Tornado 200 Fanuc OT Control - Turret indexing problem JohnWD Fanuc 10 12-29-2009 09:10 AM
fanuc 21i double turret nabil_elbadri Fanuc 2 01-11-2008 11:08 PM
Fanuc 18i - KIA SKT250MS - Turret ? Joey Fanuc 20 02-27-2007 10:23 AM
HELP! need FANUC motor for my turret press recycleroy General Metal Working Machines 1 09-28-2006 02:19 PM
