Old 02-04-2008, 03:25 PM
Noizemaker31 is on a distinguished road
Programs freeze on M08 command
I'm having an issue with an MTI dicing saw (with Fanuc 18-M) that won't read code beyond an m8 command. When an M8 (coolant pump on) command is initiated, the coolant does come on, but the program siezes at this point. The flow meter on the front of the machine shows that there is in fact flow. When I run an M8 in M.D.I. the coolant comes on and the M8 command remains on the screen. When I shut coolant of with an M9 command, the coolant switches off and the command disappears (as with every other command that has finished executing).
It seems to me that something in the saw is waiting for feedback that the coolant has been turned on, and everything freezes because this feedback never comes. M32, 33 and 34 commands (left coolant, right, or both) create errors, as they are not "installed options." It looks as though M8 is the only coolant-related functiuon that it will recognize.
Does anyone have any ideas as to what is going on here? Any input would be much appreciated...
Old 02-04-2008, 06:13 PM
Dan Fritz is on a distinguished road
All M-codes require a "Finish" signal to let the control proceed to the next block. When the relay comes on for the coolant pump, there must be a set of contacts in the relay (or maybe a pressure switch) that will confirm that the coolant is on. That switch or relay will generate an "MFIN" (M funtion finish) signal to the control.
I would guess that your control has some "Ladder" logic in the programmable controller that will show the status of all these signals. See if you can find the "Ladder" display, or (better yet), some Ladder documentation from the machine tool builder.
Old 02-05-2008, 01:41 PM
Thank you for this advice Dan. I (as well as some of my genius colleagues) are going to get out the manual and dig in search of anything regarding "Ladder Logic" that we can find.
When we get this squared away I will post a reply with whatever ends up being the answer to our problem.
Thanks again!
Old 02-06-2008, 10:30 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question Broken wire?
Dan Fritz will be right about the MFIN signal.
Can you examine the internal PROGRAM CYCLE CODE for M8.
It will probably give you a good clue to what's hanging.
Most likely this CYCLE is never returning.
If the code looks OK and is not currupted or weird, look for a broken wire from the pressure switch or coolant contactor auxiliary contacts.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Need info about freeze clamping maartenlecleir Work Fixtures and Hold-Down Solutions 18 09-11-2007 06:41 AM
Repeat command on TL-1? Haeusser Haas Lathes 4 07-31-2007 05:31 PM
Home command mgirard Mach Mill 0 05-22-2007 01:30 PM
Computer Freeze rweatherly Machines running Mach Software 0 12-06-2006 01:56 PM
what is the same command? hop G-Code Programing 0 06-20-2006 05:24 AM
