Results 1 to 2 of 2
Thread: G62
    Registered samu's Avatar
    Feb 2007
    quebec
    G62
    I want to use G62 (automatic corner override) on my hardinge VMC1000 with fanuc O-MD controller but it doesn't work.Parameters 213 (minimum deceleation ration of inside circular cutting speed), 214(deceleration ration of inside corner automatic override), 215(inside judgment angle of automatic corner override at inside corner part), 580 and 581 (end point deceleration distance) seems to be correctly set. is there any other parameters to activate automatic corner override??
    Jun 2005
    us
    Mine only works using cutter comp . Going around small rad. it slows down about 80 percent.
