I was told that in order to utilize the mirror image feature there is a certain proceedure which requires that you kill the main power and restart the machine prior to resetting you work offset(s). This is where I seem to have the problem. When I attempt to mirror the program about the x-axis I run into a problem with the G54 offset. I am sure that I must compensate for the differences between the before and after mirroring x-coordinates, but I am unsure exactly how to do this...
LinkBack URL
About LinkBacks
