Old 01-22-2008, 04:13 PM
RdHawg is on a distinguished road
Resetting the default Work offset code.
On a Fanuc 160is-m control is there an easy way to change the default work offset?
Ie. right now when I hit the reset key the controller always goes to G54 - I would like to be able to change that to the fixture offset of whatever part I'm currently working on.
Old 01-22-2008, 04:19 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Why do you want to do that?The program changes it in to what ever you want it to be.
Stefan Vendin
Old 01-23-2008, 01:12 AM
dcoupar's Avatar
I believe parameter #1201 bit 7 (WZR) controls whether the Work Coordinate system is set to G54 upon reset. (0 = no, 1 = yes). Yours is probably set to 1?
Old 01-23-2008, 10:05 AM
Because sometimes I restart a program in the middle of it and the controller never reads the line with the offset in it. (Not good)
Old 01-23-2008, 10:08 AM
My #1201 Has ZPR over bit 7? Same thing? Where could I double check that before I do something tragic?!
Old 01-23-2008, 02:08 PM
psevin is on a distinguished road
Par. 1201 bit 7 is WZR -
Upon reset, the workpiece coordinate system is:
0 : Not returned to that specified with G54
1 : Returned to that specified with G54
bit 0 is ZPR -
Automatic setting of a coordinate system when the manual reference
position return is performed
0 : Not set automatically
1 : Set automatically
Note that - ZPR is valid while a workpiece coordinate system function
is not provided. If a workpiece coordinate system function is provided, making a manual reference position return always causes the workpiece coordinate system to be
established on the basis of the workpiece origin offset (parameters No. 1220 to No. 1226), irrespective of this parameter setting.
Hope this helps.
Paul Sevin - Ovation Engineering, Inc.
http://www.ovationengineering.com
Old 01-23-2008, 02:40 PM
Ok.So if you have G55 in your program and reset it and start over, it uses G54?
I have made it a habit to always read the work zero in what ever program I'm running before I start over.
Stefan Vendin
Old 01-23-2008, 03:15 PM
codyst is on a distinguished road
Mitsui, he's not starting over from the beginning, he's starting the program in the middle. Since his work coordinate is called at the beginning of the program it doesn't get reinstated when he starts from whatever line number he chooses to restart at.
Old 01-23-2008, 06:24 PM
I know.Read the work zero in the beginning and then turn to edit,step down to where ever you want to start,turn to prog. and run.
Stefan Vendin
macro program for work offset cncwhiz Fanuc 4 12-14-2007 06:28 AM
Work Offset Question Cartierusm Mach Software (ArtSoft software) 17 11-29-2007 03:50 PM
Running one work offset. ltmquik Haas Mills 20 09-07-2007 01:02 PM
Changing Work offset from the program WITOMCIO Haas Mills 16 05-14-2007 07:40 AM
work offset in fanuc 6m b- help rags Fanuc 14 08-03-2006 09:39 PM
