Results 1 to 8 of 8
Thread: Hello all,
    Jan 2008
    Unhappy Hello all,
    We have just set up our first CNC machining centre, so I'm pretty new to all this. It's a Bridgeport 412X Interact with Fanuc O-Mate M control. (1991 machine). We got it used and the manuals don't seem to be the greatest. I have made a program that uses the tool changer, and that seems to work all right, but I can't figure out how to change tools in MDI mode.
    The manual says to enter G30 G91 Z0 T(number) M06 in MDI mode. I do that and the Z axis moves to the tool change position, (the "Z-axis at tool change position" light comes on, so it must be at the right position), but now it just sits there and doesn't do anything more. Any ideas? Maybe a modal G-code not set right?
    Note that I use exactly the same code in my program that does work
    Thanks for your help,
    Lorne
    Registered Mitsui Seiki's Avatar
    Feb 2007
    Try to put M6 on a seperate line after "G30 G91 Z0 T(number)"
    G30 G91 Z0 T(number) ;
    M6;
    Stefan Vendin
    Jan 2008
    thanks for the quick reply. I tried that, but still no go. Any more ideas?
    Feb 2007
    Try this:
    G30G91Z0;
    T#;
    M19;
    M6;
    Stefan Vendin
    Jan 2008
    OK, we're getting closer. The M19 is orienting the spindle, but still no tool change
    Feb 2007
    Yes, but you should find M19 in the M6 macro.
    Strange.M6 works inside a program but not in MDI?
    Ok,try to do this:
    G80G40G49
    G30G91Z0
    T#
    M19
    M6
    Stefan Vendin
    May 2006
    Netherlands
    Use M16 instead of M6. Be sure z-axis is at zero
    Jan 2008
    We finally had a tech out. He couldn't figure it out either, but it turns out there's a small program you have to run in auto mode to rotate the turret, seems kinda wierd, but I guess it works.
  • Posting Permissions
