Results 1 to 4 of 4
Thread: system variables vs parameters
    Feb 2006
    india
    Are system variables of macros and machine parameters similar (why should these be treated as different)?
    If yes, is it possible to set machine parameters through a macro?
    Of course, if a machine does not have Custom Macro B, then this question does not arise.
    Dec 2003
    Variables are just that, storage registers, they can be manipulated by program commands to achieve mathematical results, or system Variables can be read to inquire the machine state etc.
    Parameters are settings that configure the machine characteristics such as servo tuning, encoder resolution and machine options as a few examples.
    Mar 2005
    Silicon Valley, CA
    Yes, it is possible to set/change some machine parameters with a macro.... but not all.
    EDIT: I should add though, its more readily done by using G10
    It's just a part..... cutter still goes round and round....
    Feb 2006
    india
    This example is from Oi-MB manual (P. 366):
    G10 L50;
    N3404 R00000100;
    G11;
    My question is that why is it not permitted (or is it permitted?) to simply use
    #3404 = 4; in the main program or in a macro (decimal 4 is equivalent to binary 100), which will make our life much easier !! Afterall, some system variables are read/write type, which can be modified as well. Why does the control differentiate between parameters and system variables?
    Of course, when the same parameter refers to different axes, as in the following case (taken from the same manual), it may not be possible:
    G10 L50;
    N1322 P3 R4500; (modify Z axis)
    N1322 P4 R12000; (modify A axis)
    G11;
    Incidently, can we write N3404 R4 in the first example? Is it that some R words must be binary while some other must be decimal?
  1. System variables
    By cncwhiz in forum Fanuc
    Last Post: 01-17-2008, 11:27 PM
  2. System variables in a O-MD
    By AZDEN in forum Fanuc
    Last Post: 10-23-2007, 11:50 AM
  3. Output parameters as variables
    By viorel26 in forum Fanuc
    Last Post: 10-03-2007, 03:14 AM
  4. System variables
    By jorgehrr in forum G-Code Programing
    Last Post: 02-18-2007, 08:26 PM
  5. Mori Seiki MF-T6 System Variables
    By EvilScooby in forum General CAM Discussion
    Last Post: 06-12-2003, 08:32 PM
