I don't know the exact values but this tells you what they are for.
Code:
5615 Spindle motor speed during the spindle gear shift
Parameter input (Not used in the Series 15傍T)
Data type : Word
Valid range : 0 to 4095
Specify the spindle motor speed during the spindle gear shift.
This parameter is valid for the FS3 or FS6 interface.
Time from when a spindle gear select single is issued
5616 until when the new spindle speed is output
Data type : Word
Unit of data : msec
Valid range : 0 to 32767
When the type of spindle speed analog output or spindle speed binary output is A (TPB in parameter No. 5601
is set to 0), specify the time from when a spindle gear select signal is output until when the new spindle speed
corresponding to the specified gear is output.
This parameter is valid when the FS3/FS6 interface is used.
5617 Spindle speed during the spindle orientation
Data type : Word
Unit of data : rpm
Specify the spindle speed during the spindle orientation.
5618 Minimum clamp speed of the spindle motor
Data type : Word
Specify the minimum clamp speed of the spindle motor.
Setting = (minimum clamp speed of the spindle motor/spindle motor speed corresponding to the
maximum output) x 4095
5619 Maximum clamp speed of the spindle motor
Data type : Word
Specify the maximum clamp speed of the spindle motor.
Setting = (maximum clamp speed of the spindle motor/spindle motor speed corresponding to the
5620 Time until the speed arrival signal is checked
Data type : Word
Unit of data : msec
Specify the time from when the S function is executed until when the speed arrival signal is checked.
Checks whether the speed arrival signal is on at the beginning of the cutting feed (G01, G02, G03, etc.) block.
If it is off, the system waits until it is turned on, then begins the pulse distribution.
When the cutting feed is specified in the same block as the S function, waits for the specified length of time after
the S code is sent, then checks the speed arrival signal. (See the diagram above.)
5621 Maximum spindle speed corresponding to gear 1
5622 Maximum spindle speed corresponding to gear 2
5641
Minimum spindle speed of gear 1 under the constant
surface speed control
5642
Minimum spindle speed of gear 2 under the constant
