Does anyone know where I can download a comprehensive manual for Mori Caps-M? Or is anyone pretty good in it and can answer questions I have? We used to have a machining supervisor who hid all the manuals to enhance his own job security. He is now gone and they are lost. I have capped on this machine for a couple years and know the software well enough. Now I want a way to know it better. For instance, in the contour side cutting screens, in lines or arcs, under "details", one choice is "closed calc", with the choices valid or invalid. Whats that about? The capping is on a separate PC and has on the initial screen Machine Type SV-50 NC Type 515,FS-15M |
| It'd been long I have touch Caps-M, I don't think I can help you much. I think Closed calc is for clearance, and not quite sure, and if Caps-M is too important, than call up Mori and order one because I don't think they put anything on line for download.
__________________ The best way to learn is trial error. |
| Learning all I can will enhance job security now AND improve my resume, juneau? I'll try to do screen captures on the screens I can't figure out wed.. |
Here is a screen cap from the contouring screen (arc). Everything below "arc decisin" (dontcha love software translated from Japanese) appears after pressing the "details" key (f2). Anyways, the "center angle" is kinda obvious, it is the degrees of the arc if known. A fairly common problem is that the arc you are attempting to program describes a full circle instead of going tangent to the next arc or line. If you could force the arc to not go 360 degrees without knowing the precise degrees, that would be a big help. It won't accept a greater than or lesser than symbol (< or >). The aux. pt. 2 x and y are related to the angle choice below them (same help screen), but I don't have a clue. If I could figure out what "arc decisin" ("auto" or "another") and "closed calc" ("valid" or "invalid") do exactly, it might tie it all together. They effect the other choices. "Closed calc" also appears on the other screens in contouring. |
| I know that the arc descision helps to determine the quadrant(s) the arc is going to pass through. I use CAPS II for a mill turn, a little different, same idea. I don't have a closed calc choice though
__________________ You CAN do anything, if you REALLY want to, but how many people really want to? Kyle |
| Hmmm, I'll play with it Monday to see what I can figure out. Do you have any idea what to input where? I could see how picking a quadrant to lock it into could be handy. Thanks for the answer. |
| RPC Caps question | choppersprocket | Phase Converters and VFD | 6 | 12-12-2006 05:24 PM |
| CAPS information | Kaymen | G-Code Programing | 2 | 08-22-2006 01:17 AM |
| emi filtering caps ? | andy55 | General Electronics Discussion | 1 | 01-08-2006 03:57 PM |
| Have 3 caps, which one to use? | juxtoposed | General Electronics Discussion | 6 | 04-21-2005 12:43 PM |
| PSU & CAPs & Motor Questions.. | TTaki | Gecko Drives | 0 | 11-02-2004 09:43 PM |
