Page 1 of 3 123 LastLast
Results 1 to 12 of 25
Thread: Entry exit arc leaving bump
    SIG
    SIG is offline
    Sep 2007
    Oi MC control.
    When I use entry exit arcs while side milling a round or square boss I get a
    .001 bump on side of part. The program is right but for some reason the machine never get to the final endpoint before arcing out. Does anyone have an idea why?
    Dec 2005
    UK
    Hi SIG
    I am probably the least qualified to answer this but have you tried:
    Reducing feed rate? .... I have seen m/c take a new command before fininshing the first!
    Overlapping the start and finish points?
    Regards
    Richard
    Registered V1T1CO's Avatar
    Nov 2007
    Sig:
    what I do to avoid this issue is, include an overlap, .025" should be enough, the other approach is to take a zero pass around your boss w/out retracting,...
    Hope I was able to help.
    Regards:
    V1T1CO
    May 2007
    Your machine could be over (or under) compensating for backlash - put an indicator on your part, and manually move it with your handwheel a tenth (.0001), then move it back. If it is overcompensating, there will be a jump on the indicator. Under compensating would result in no movement. Fixing that is just a simple parameter change (although I don't know which one).
    Also, it may be possible that you are somehow in exact stop mode? If so, the machine will pause briefly between execution of each block, and it may leave a dwell mark. I don't know how to change that offhand on a FANUC machine, I know on my FADAL I turn it off with a G08.
    And, lastly, if you don't want to overlap your start and end points, as suggested, you can start and end on a corner, where a bump will not show up.
    SIG
    SIG is offline
    Sep 2007
    Quote Originally Posted by rgammage View Post
    Hi SIG
    Reducing feed rate? Overlapping the start and finish points?
    Richard
    Yes.
    Yes that works but I was thinking shouldn't a machine with the latest control follow its intented path. I have an 85 tiger 3 that would not do this.
    Quote Originally Posted by V1T1CO View Post
    Sig:
    Regards:
    V1T1CO
    Do you have this problem too?
    Quote Originally Posted by Phyrexii View Post
    I'll try moving hand wheel .0001 back and forth.
    I don't think its dwell because this is leaving stock on.
    On a square part starting in corner does work but its still a problem on parts I'am trying to make round.
    This is a new machine for me and I did check backlashes and they seem fine.
    Our old machine has and 85 tiger 3 on it and would all ways follow its path. It just ran slow, so we upgraded.
    When I cut a round cavity it takes .0002/.0003 off at each quadrant.
    It seems like a backlash problem but I've checked them and they seem OK.
    I will check them again.
    Thank you everyone for your repleys
    May 2007
    One other thing I just thought of -
    Turning cutter comp on/off - make sure you are not turning it on or off during your entry arc move. I always include an extra move there to insure that the tool is in the correct position prior to entering the cut. Cutter comp can do some strange things as the control is positioning the cutter, and may be moving the cutter off the cut early to compensate (or something ;-).
    Dec 2007
    uk
    Cool just a suggetion
    hi... i would suggest comping on/off to an imaginary point of the componant (away from the componant)if possible as u will allways get a slight digin where the tool has on/off in the same spot.
    hope this helps
    antoon
    Nov 2006
    UK
    You could also try a larger roll on/roll off arc.
    Registered Mitsui Seiki's Avatar
    Feb 2007
    I don't know what the program looks like but try to pur two "blind blocks" before G40.
    Stefan Vendin
    Dec 2007
    just travel past the point where you turned comp on-then roll off
    SIG
    SIG is offline
    Sep 2007
    I'am not using cutter comp just G1,2 & 3 w/ I & J's.
    I also just learned about exact stop and thats not it. It leaving stock on not stock off like a dwell might do. Good idea though and I did learn something I did not know about before.
    Feb 2006
    india
    I think, the bump is the result of the next command starting before the end of the previous command. This does happen. Because of this reason, if you give two pependicular moves, you will observe some rounding-off of the corner. If you want a sharp corner, use "exact stop" feature (G09) instead of just G01. Another way is to insert a dwell command between the two moves.
    In your case, instead of reducing the feed (which will waste time), introduce a dwell (G04) of, say one second, between all moves where you are getting a bump. If it still does not work, try a higher dwell time. This will, of course, leave a "water mark" on the surface, but the surface will be smooth.
  • Page 1 of 3 123 LastLast
    1. bump in drive system...?
      By REVCAM_Bob in forum Servo Motors and Drives
      Last Post: 06-03-2007, 05:20 PM
    2. How to exit large assembly mode?
      By interflexo in forum Solidworks
      Last Post: 09-25-2006, 04:21 AM
    3. Bump mapping
      By MrRage in forum General CAM Discussion
      Last Post: 09-02-2005, 05:43 PM
    4. One more little bump in the ProtoTrak post
      By Shadowfaxx in forum Post Processors for MC
      Last Post: 01-04-2005, 11:10 PM
    5. Extending toolpath entry and exit points?
      By microdot in forum GibbsCAM
      Last Post: 08-25-2004, 04:06 PM
    Visitors found this page by searching for:
    Nobody landed on this page from a search engine, yet!
    SEO Blog
