Results 1 to 9 of 9
Thread: Autocad to Gcode on Amada Turret
    Sep 2007
    Sri Lanka
    Smile Autocad to Gcode on Amada Turret
    Hi All,
    Pls let me know any autocad to gcode software that can support AMADA Turret Punch 244 with Fanuc 6M
    Thanks & Regds
    Chinthaka
    Sep 2007
    Mexico
    Autocad is just a design software, to get the code you'll need a CAM and the postprocessor, you can use CAMSOFT, for information you can ge to their page or ask in the Camsoft forum here; it think it works fine with that machine.
    GP.
    Sep 2007
    Sri Lanka
    Thumbs up Thanks GP
    Thanks GP I will do it
    Jun 2007
    vietnam
    Talking
    Quote Originally Posted by chinthakahk View Post
    Hi All,
    Thanks & Regds
    Chinthaka
    I'm using AMADA2D Cad/Cam software. It's a DOS version but works smart. It supports many kind of AMADA turret punch press such as OCTO, COMA, PEGA, VELA...with Fanuc 6M. You are just export your drawing into .dxf format then open it by AMADA2D then choose machine, turret, choose Tool for object then go to Post processor, that's it. It's also has simulator that you can see position of clamps, sheet, holes...
    Sep 2007
    Sri Lanka
    Thanks Nguyenthanthi,
    But im unable to find any souce about it on the net. Pls let me know any link pls.'
    Chinthaka
    Jun 2007
    vietnam
    I'm sorry caused you confuse. It is just another name of the software. If you search on the net you can use key word "amp1e amada software". Good luck
    Mar 2007
    To go from Autocad into GCode for the turret, you need a piece of software called a sequencer or post-processor. The sequencer is where you tell the software which tools should hit where along the design. The software then outputs GCode that can run on your turret.
    I use one called GPuncher (previously called KZXCad), and am quite happy. You can import DXFs from Autocad into it, or you could design the parts from scratch in it.
    Gpuncher is only $375, and I don't think there are any other similar products for less than $1,000 (most are more like $4,000). Its a small software company, and the owner has been very responsive in making bug fixes or helping out whenever I needed. Even though it is really inexpensive, I think it has just about every feature that the more expensive ones have. There was a bit of a learning curve to start using it, but it really does work and works well.
    You can find it at http://www.metalpuncher.com/ .
    Nov 2010
    $ 49.95 on Ebay
    NC Punch G-code Editor + Simulator for Amada CNC Turret
    Feb 2006
    india
    If you do not want to spend a penny, and have some time as well as patience, you can extract information about different lines/curves of an AutoCAD drawing using LIST or PROPERTIES command. Thereafter, you can write a program yourself using G01/G02/G03, with or without radius compensation, as needed. Of course, for a 3D drawing, this technique will not work.
    1. Autocad to gcode
      By JamesMI in forum Autodesk Software (Autocad, Inventor etc)
      Last Post: 12-02-2011, 03:54 AM
    2. Amada Fanuc 0L problem laser
      By rick_7037 in forum Fanuc
      Last Post: 12-16-2006, 03:48 PM
    3. CNC Amada Apelio G-Codes
      By pwright238 in forum G-Code Programing
      Last Post: 10-16-2006, 04:05 AM
    4. Nisshinbo CNC code & Amada LASMAC 667 II
      By Independent CNC in forum General Waterjet
      Last Post: 09-16-2006, 06:00 PM
    5. Gcode verify autocad plugin
      By balsaman in forum General CAM Discussion
      Last Post: 10-31-2003, 12:22 PM
