Old 12-11-2007, 05:35 PM
cncwhiz is on a distinguished road
macro program for work offset
I have been going back and forth with a few guys on another topic on four axis programming. They were talking about using a macro to calculate the position of part position. Now they did it, they made me think I am working on a post for a machine we have here in our shop. This controller is a "FAPT" control and will not allow "G54.1". I need to program my angle holes on the parts from the centerline "X, Z". I need to use "G10's" to do this. I need to shift my "G54, G55" back and forth to get this done as that the remaining work on the parts are done on the face of the part. I was working on my post to use a "G10" shift line to go from the centerline to the face of the part. The problem with this is everytime the shift takes place the is a "G10" line. When they need to adjust the work offsets, they need to change all of them. If they forget then they can scrap parts. I want to build a macro to control this. The first macro will be controlled by the system variable for "G54, G55 Z". The other macro will just be the distance from the spindle face to the center line of the "B axis" Does anyone have either the macro to do this or a list of system variables so I can build these macros? I have built some simple macros for the machines allready so I have a general understanding of what I need to do.
TIA
TIA
Old 12-12-2007, 10:56 AM
*Registered User*
Bluesman is on a distinguished road
TIA
TIA
Like This ???????? It calculates position at an angle from the X Z position on the Fixture.
:8701(MOVE SIDE)
(SIDE B)
#150=710.-ABS[#5223]
(SIDE C)
#151=ABS[#5221]
(ANGLE THETA)
#152=[ATAN[#150]/[#151]]-11.000(ANGLE)
(SIDE A)
#153=SQRT[[#150*#150]+[#151*#151]]
(NEW SIDE B)
#154=#153*[SIN[#152]]
(NEW SIDE C)
#155=#153*[COS[#152]]
(X AXIS ADJ)
#156=#155-#151
(Z AXIS ADJ)
#157=#150-#154
#528=ABS[#156]
#529=ABS[#157]
G91
G10L2G54P01X#528Y0.0Z-#529 (LOAD WORKSHIFT)
G90
#150=#0
#151=#0
#152=#0
#153=#0
#154=#0
#155=#0
#156=#0
#157=#0
M99
:8702(RETURN FACE)
G91
G10L2G54P01X-#528Y0.0Z#529(CLEAR WORKSHIFT)
G90
#525=2
#528=#0
#529=#0
M99
:8703(MOVE @ LEFT)
(SIDE B)
(SIDE C)
#151=ABS[#5221]
(ANGLE THETA)
(SIDE A)
(NEW SIDE B)
(NEW SIDE C)
(X AXIS ADJ)
#156=#155-#151
(Z AXIS ADJ)
#157=#150-#154
#528=ABS[#156]
#529=[#157]
G91
G10L2G54P01X-#528Y0.0Z-#529(LOAD WORKSHIFT)
G90
#150=#0
#151=#0
#152=#0
#153=#0
#154=#0
#155=#0
#156=#0
#157=#0
M99
:8704(RETURN @ LEFT)
G91
G10L2G54P01X#528Y0.0Z#529(CLEAR WORKSHIFT)
G90
#525=2
#528=#0
#529=#0
M99
Old 12-12-2007, 11:55 AM
That is cool macro. Are you using the center of the tonbstone to calculate the angle? The is missing sides to the angles to calculate? Also lets say that my part is 10 inches from the center line. When it rotates, this is not a typical right triangle? The do you canculate this? The rotation is actually a for lack of better words a radial tringle? Also how do you set your tool offsets and "Z" plane? Do you calculate from gage line zero? You reset all of your values so where are your known distances or missing sides of the triagle?
Old 12-12-2007, 01:20 PM
*Registered User*
Here is a whole exsample i have the Main goemetry and the calc subs,Just follow it in and out and you should be able to figure it out
Bluesman
Old 12-14-2007, 06:28 AM
Sump Cleaner's Avatar
Sump Cleaner is on a distinguished road
Cncwhiz,
I program like this all of the time. We have horizontal machines so you might need to change this around a bit. Also, I do use G54.1P1 but there is nothing to say you can't use G54 to G59 for this.
:0002(PALLET A)
#149=0(THIS TELLS THE CONTROL TO READ PALLET A COORDS)
M98P1000
M30
:0003(PALLET B)
#149=1 (THIS TELLS THE CONTROL TO READ PALLET B COORDS)
M98P1000
M30
:1000(2342 ALL MAIN)
(2342A&B REVD)
(2342C REVE)
(15NOV07 JK)
(LAST RUN 15NOV07)
(0M0S)
(DO NOT ADJUST ANY X OR Y)
(VALUES IN MAIN PROGRAM)
G0G17G40G80
G90G94G98
G91G28Z0
M1(DRILL LONG PORT)
G0G17G40G80
G90G94G98
T1M6(S2342-6)
B90.
M98P1100
S3500M3
G54.1P1X0Y0M8
G43Z1.2H1T2
G81Z-1.143R.1F18.
G54.1P2X0Y0
G80G0Z2.5
G54.1P4X0Y0
Z1.2
G81Z-1.143R.1
G54.1P3X0Y0
G80G0Z6.M9
G91G28X0Y0M29
M1(DRILL SHORT PORT)
G0G17G40G80
G90G94G98
T2M6(S2342-5)
B270.
M98P1100
#502=0(THIS IS THE SIGNED DISTANCE FROM THE X DATUM OF THE PART)
#503=-2.09(THIS IS THE SIGNED DATUM FROM THE Z VALUE OF THE PART)
M98P1200
S3500M3
G54.1P3X-.562Y0M8
G43Z1.H2T3
G81Z-.66R.1F18.
G54.1P4X-.562Y0
G80G0Z2.5
G54.1P2X.562Y0
Z1.
G81Z-.66R.1
G54.1P1X.562Y0
G80G0Z6.M9
G91G28X0Y0M29
M1(1/4-18 NPT)
G0G17G40G80
G90G94G98
T3M6(LAKESHORE 18NPT TRML)
(D23)
B270.
M98P1100
#502=0
#503=-2.09
M98P1200
S8000M3
G54.1P1X.562Y0M8
G43Z1.2H3T4
M98P1400
G54.1P2X.562Y0
M98P1400
G0Z2.5
G54.1P4X-.562Y0
M98P1400
G54.1P3X-.562Y0
M98P1400
G0Z3.
B90.
M98P1100
G54.1P1X0Y0
M98P1400
G54.1P2X0Y0
M98P1400
G0Z2.5
G54.1P4X0Y0
M98P1400
G54.1P3X0Y0
M98P1400
G0Z7.M9
G91G28X0Y0M29
M1(FACE)
G0G17G40G80
G90G94G98
BLAH, BLAH, BLAH..........
:1100(2342 ALL 90 COORDS)
#501=90.(THIS IS THE ANGLE FROM ZEOR ON THE AXIS TO WHERE YOUR PARTS ARE)
#101=-9.921(THIS IS THE DIST FROM MACHINE ZERO TO THE CENTERLINE OF ROTATION IN X)
#102=-20.4725(THIS IS THE DIST FROM MACHINE ZERO TO THE CONTERLINE OF ROTATION IN Z)
IF[#149GT0]GOTO10
(PALLET A)
(G54.1P1 LEFT TOP)
G10L20P1X-14.149Y-7.854Z-19.552
(G54.1P2 LEFT BOTTOM)
G10L20P2X#7001Y-11.522Z-19.552
(G54.1P3 RIGHT TOP)
G10L20P3X-5.694Y-7.854Z-19.552
(G54.1P4 RIGHT BOTTOM)
G10L20P4X#7041Y-11.522Z-19.552
GOTO20
N10
(PALLET B)
(G54.1P3 RIGHT TOP)
N20
M99
:1200(2342 P1-4 TRANSLATION)
#504=#7001(SETS #504 TO X VALUE)
#506=#7003(SETS #506 TO Z VALUE)
M98P1300
#7001=#512(REWRITES X VALUE)
#7003=#513(REWRITES Z VALUE)
#504=#7021
#506=#7023
M98P1300
#7021=#512
#7023=#513
#504=#7041
#506=#7043
M98P1300
#7041=#512
#7043=#513
#504=#7061
#506=#7063
M98P1300
#7061=#512
#7063=#513
M99
:1300(2342 TRANSLATOR)
#510=ATAN[#101-#504-#502]/[#102-#506-#503] (CALCULATES THE ANGLE)
#511=[#102-#506-#503]/COS[#510](CALCULATES THE RADIUS)
#512=#101+[SIN[#5024-#501-#510]*#511](CALCULATES THE NEW X COORD)
#513=#102-[COS[#5024-#501-#510]*#511](CALCULATES THE NEW Z COORD)
M99
This is the general idea I use but the explanation may be a bit bleek. If you want to pursue this idea more, let me know and I will try to give you a better explanation. After all, it is the last Monday of the week!
Cheers Guys...
JK
Macro program pioneerproducts Product Announcements & Manufacturer News 4 10-08-2007 03:44 PM
Changing Work offset from the program WITOMCIO Haas Mills 16 05-14-2007 07:40 AM
How to set part program offset wayneman Bridgeport and Hardinge Mills 0 01-25-2007 12:22 PM
Macro for positive offset qmas99 General CAM Discussion 0 02-11-2006 09:37 PM
change offset in program jianjianca G-Code Programing 11 12-22-2005 10:48 AM
