I have a fanuc series 5t controller on my mori lathe and I do not understand how to input the g-codes and m-codes manually. I have it on MDI but I don't quite understand how to do the N-blocks because when you press N10 for ex. then INPUT it does a search for N10. If at all possible could anyone send me some info. on how to do this Please. |
| You use the INSERT key only in EDIT mode when you want to input data into a program in memory. For MDI, you don't key in N-numbers. You only key in one command at a time, then press INPUT and START. For example: G50 INPUT X12345 INPUT Z23456 INPUT START (sets the X and Z position) G00 INPUT U10000 INPUT W10000 INPUT START (moves the Xand Z by one inch) T0400 INPUT START (selects tool #4 with no tool offset) M03 INPUT S1000 INPUT START (starts the spinle at 1000rpm - if you have direct RPM S-codes) Each time you enter a command, you must run the address LED light to the letter (like "M" or "G"), then enter the number, then press INPUT Sometimes the START buttton under the INPUT key works, sometimes it does not and you have to press CYCLE START on the machine panel instead. There is a parameter for this. |
| Series II | Perp | Bridgeport and Hardinge Mills | 4 | 05-13-2007 11:50 AM |
| Series II Cnc | TPMX | Bridgeport and Hardinge Mills | 18 | 04-15-2007 02:47 PM |
| series II cnc | hello113 | Bridgeport and Hardinge Mills | 11 | 04-06-2007 07:02 PM |
| What is the Difference between 6000 series aluminium and 7000 series | Kosta1234 | General Material Machining Solutions | 3 | 11-19-2005 08:04 AM |
