Old 12-03-2007, 11:32 PM
msaiprasad is on a distinguished road
SRAM Backup
Hi all
Can any one tell me how to take SRAM backup or all backups i need to take on fanuc 18i
Old 12-04-2007, 07:38 PM
codyst is on a distinguished road
Power off the control(just control not the whole machine).
Press the far right arrow key and the key immediately to it's left and continue to hold as you power on the control.(Buttons directly underneath the screen)
A selection screen will appear. Press the button corresponding to "Down" until you get to SRAM and press the select key. A new screen will appear.
Scroll to "CNC--->Memory Card"(should be highlighted as soon as the screen opens) and press Select. A confirmation message will appear "Are you sure?" Press "Yes" or "No".
Once the data is loaded to the Memory card you will be asked to press the "Select" key. Then press the button corresponding to "Down" until you highlight "END". Press "Select".
Once you press select you will be taken to the main screen, again scroll down to end and press select. The control will boot up as usual.
Old 12-06-2007, 01:04 AM
Thank you
FANUC Oi-M-->Backup SRAM and Load PMC file BKCOM Fanuc 3 03-29-2011 05:43 AM
Do you use SEND ALL for backup? gar Haas Mills 7 06-28-2007 08:19 AM
Ghost HD backup OLD_Newbie General Electronics Discussion 6 06-09-2007 07:28 AM
Download to SRAM Bluesman Fanuc 1 02-16-2007 10:49 AM
Backup Script.. Rekd Mastercam 3 09-11-2003 09:34 AM
