I was asked by the production supervisor if there was any way I could add a spindle orientation to a cutting program. I thought no problem added a m41 and a m42 told him to try it and nothing happened. Does anyone know what parameters need to be changed to activate the spindle orientation on the O-i controllers. The MTB manual (Takamaz) lists these m-codes as an option and I was told by thier tech that it wasn't activated and I would need to call Fanuc ($1000 min charge to activate) Thanks Rich |
| That doesn't sound right to me. Usually, M19 is the spindle orient command, not M41 or M42. Those M-codes are usually used for manual gear changes if you have a transmission. Besides, if your spindle drive has the ability to orient (and it would if it has to orient for a tool change), then it can't be an option. M-codes are not Fanuc options anyway. |
| The ability to orient the spinel may very well be an option. It isn't apparent by your post (unless I missed soemthing) whether the machine is a lathe or mill. If it is a lathe (which is mostly what I recall seeing from Takamaz), the chances that it is an option are greater than if it is a mill.
__________________ Paul Sevin - Ovation Engineering, Inc. http://www.ovationengineering.com |
| Paul I forgot to say that it is a lathe. The big question is does anybody know what parameters need to be changed to activate the codes when used? Dan On a Takamaz lathe M19 is a 2nd coolant pump off code, unfortunately there are several M and G codes that are an option on these lathes. I tried to write a program a few months ago using a G73 and it would instantly go into a alarm because it was an option that wasn't activated when it was purchased |
| controller or not? | plasticad | DIY-CNC Router Table Machines | 1 | 09-30-2007 06:23 AM |
| DeskCNC 2nd. gen controller AND HobbyCNC Pro Controller | maycom | DeskCNC Controller Board | 1 | 06-02-2007 01:33 PM |
| All in one controller | dwacker | DIY-CNC Router Table Machines | 12 | 04-14-2007 07:28 PM |
| What about this controller? | carbidecraters | CNC Plasma and Waterjet Machines | 2 | 03-01-2006 08:54 AM |
| CNC controller | justCNCit | General Electronics Discussion | 2 | 03-23-2004 01:32 PM |
