All of the settings below are in the Parameter manual for this control. Parameter 0100 Bit 1 (CTV) Character counting for TV check in the comment section of a program. 0 : Performed 1 : Not performed Bit 3 (NCR) Output of the end of block (EOB) in ISO code 0 : LF, CR, CR are output. 1 : Only LF is output. Bit 5 (ND3) In DNC operation, a program is: 0 : Read block by block. (A DC3 code is output for each block.) 1 : Read continuously until the buffer becomes full. (A DC3 code is output when the buffer becomes full.) Bit 6 (IOP) Specifies how to stop program input/output operations. 0 : An NC reset can stop program input/output operations. 1 : Only the [STOP] soft key can stop program input/output operations. (An reset cannot stop program input/output operations.) Bit 7 (ENS) Action taken when a NULL code is found during read of EIA code 0 : An alarm is generated. 1 : The NULL code is ignored. Parameter 0101 (assuming that I/O CHANNEL=0) Bit 0 (SB2) The number of stop bits 0 : 1 1 : 2 Bit 3 (ASI) Code used at data input 0 : EIA or ISO code (automatically distinguished) 1 : ASCII code Bit 7 (NFD) Feed before and after the data at data output 0 : Output 1 : Not output Parameter 102 Set the number specified for the input/output device used when the I/O CHANNEL is set to 0 Set value=0 - RS–232–C (Used control codes DC1 to DC4) Parameter 0103 Baud rate (when the I/O CHANNEL is set to 0) Set value Baud rate (bps) 1 50 2 100 3 110 Skipped a bunch of unused baud rates 8 1200 9 2400 10 4800 11 9600 12 19200
__________________ Paul Sevin - Ovation Engineering, Inc. http://www.ovationengineering.com |
| NEED FANUC 18-TB PARAMETERS | icnc | Fanuc | 0 | 11-21-2007 09:56 AM |
| Fanuc 0-T parameters | BigGrilla | Fanuc | 15 | 09-26-2007 07:43 PM |
| Fanuc 0T G83, G84 parameters | davisboys | Fanuc | 0 | 03-17-2007 11:29 PM |
| Fanuc 3M Parameters | nastek | Fanuc | 9 | 12-29-2006 07:35 AM |
| Fanuc 18T - Parameters | pinguS | Fanuc | 7 | 04-11-2006 06:20 PM |
