Results 1 to 2 of 2
Thread: TOOL SETTINGS FOR MY FANUC 18M VMC
    Registered PICMAN's Avatar
    Aug 2005
    Angry TOOL SETTINGS FOR MY FANUC 18M VMC
    PLEASE HELP,
    IM HAVING PROBLEMS SETTING UP MY TOOLS. I KNOW IM DOING IT THE HARD WAY. I THINK I CAN USE TEACH OR OFFSET MEASURE TO AUTOMATICALLY CALCULATE MY TOOL POSITION. IM JUST NOT SURE HOW TO GET THERE.
    THANKS
    PICMAN
    Mar 2006
    The following is for Fanuc 18-MC, not sure what you have.
    You need to have a reference tool (eg zero offset).
    1 Use manual operation to move the reference tool until it touches a specified position on the machine (or workpiece - usually your datum face.)
    2 Press function key POS several times until the current position display screen with relative coordinates is displayed.
    3 Reset the relative coordinate for the Z–axis to 0.
    4 Press function key OFFSET SETTING several times until the tool compensation
    screen is displayed.
    5 Use manual operation to move the tool to be measured until it touches the same specified position. The difference between the length of the reference tool and the tool to be measured is displayed in the relative coordinates on the screen.
    6 Move the cursor to the compensation number for the target tool (the cursor can be moved in the same way as for setting tool compensation values).
    7 Press the address key Z .
    8 Press the soft key [INP.C.]. The Z axis relative coordinate value is input and displayed as an tool length offset value.
  1. Fanuc 11m Tool Comp
    By Jfrahm in forum Fanuc
    Last Post: 07-29-2007, 06:01 PM
  2. Tool change on Fanuc OT
    By steedspeed in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 09-11-2006, 04:37 PM
  3. fanuc 18i programming with tool changes
    By krustykrab in forum Fanuc
    Last Post: 12-03-2005, 06:51 AM
  4. 2010 Tool Not Available - Fanuc Om
    By PPM in forum Fanuc
    Last Post: 08-24-2005, 04:22 PM
  5. Quesion regarding inhibit jumper settings for Fanuc drive
    By cncboy in forum CamSoft Products
    Last Post: 03-07-2005, 06:43 PM
