Page 1 of 3 123 LastLast
Results 1 to 12 of 34
Thread: Manual Setting of Work Zeros (0-M fanuc)
    Registered venomgrrrl's Avatar
    Nov 2007
    canada
    Unhappy Manual Setting of Work Zeros (0-M fanuc)
    I am trying to tell my mc (Shizouko millmaster) where the part zero is.
    To start I am accustom to Haas, Maho.
    Generaly i find setting wrk0`s my position pretty common.With this Fanuc I know where to put my wornk zero`s once i have found my zero position (my menu offsets page)...
    my problem is zeroing my axis, X & Y ( i am using an e.mill to position)
    So I touch-off, and i would usally zero my axis here, move rad. of cutter, touch other side of piece (move rad.) div. this by 2 to be at center.
    My cutter is where zero should be...i cannot find where to imput this into m.c. I am not using any g54`s as is only one piece
    I could be way off, but this is how i usally set my work zeros...thanks!
    Sep 2007
    Mexico
    I will suggest that you use G54...G59 in case your machine has them. In case it doesn't have them you can use G50 or G92. In G54 you write the number corresponding to the machine position when the tool is located at the zero that you want, ie. center of the piece.
    Nov 2007
    canada
    Thumbs down
    I Have set a G54 ( and tried the putting in the Absolute positionong co-ords,
    this still is bringing me off by a few inches away from my actual work zero,
    so i tried putting in the Machine co-ords and am getting the same results
    This is the first time ive ever had a prob. w my work zeros, makes for a interesting day!!
    Sep 2007
    Mexico
    Mmmmmm...where the G54 is locates on the work offset screen there is a group above, this is to shift the coordinates and must be all zero (X,Y,Z). Is it all zero???
    Nov 2007
    canada
    yea its at zero x,y and z.
    there is 6 co-ord settings G54=01 G55=02 G56=03 and so on,
    the one above 01 is 00, i assume this is the one you are speaking of, I dont know exactly what it is for but its all at zero
    so do you usally set your Absolute co-ords, or machine co-ords,
    thanx so much for reply...my butt is on the line!! LOL
    Nov 2007
    canada
    when zero returning your machine does it bring X far to the right as it can go before overtravel
    as welll with Y
    I do not think mine is properly Homing itself
    Nov 2007
    canada
    On my Haas machines home is always nicley tucked away in the far X+ Y+ corner, on this Shizouko, its table is practicly center to the doors...wierd
    Sep 2007
    Mexico
    Is it homing fine???? If you do not home the machine it won't take the right coordinates.
    Are you using G90 to set absolute coordinates??
    The coordinates that you must input in the G54 offset are the machine coordinates, not absolute or relative.
    If it is a fanuc 6 please check that the ABS button is on.
    Jan 2004
    Gardnerville,Nevada
    I would use the "machine" position to establish your zero. Some fanuc's mess with the position screen. You should do what you are doing but when you get to center use the machine position to set the "g54"
    Moderator HuFlungDung's Avatar
    Mar 2003
    How ancient is this controller? If its really stubborn, after the machine has homed, try keying in G92 X0Y0 in MDI and then execute it. Then try setting a work offset. Or if you prefer, you can dispense with setting the work offset, simply move your machine to the work datum, and execute G92 X0Y0 at that location. If you do this in MDI, then the machine position will be established for as long as the power is on, and you don't need to write the G92 into the main program, which has certain dangerous ramifications if you restart out of position.
    Nov 2007
    canada
    There are 3 positioning screens
    1: Absolute = reads X0, Y0, when machine in nHOME position
    2: Relitave = can manually set ZERO's with this pg
    3: Machine = is normally what I would imput into my offset pg (G54 ect)
    My command line reads like this: G90 G80 G54 G49 G40
    Whats happining when It reads prgm to go to work zero (G0 X0 Y0) my screen reads out like so:
    Absolute X0.0 Y0.0
    Relative X-1.25 Y-2.5* (*aproxomite co-ords)
    this X1.25, Y2.5 is exactly how far machine is frm work zero.
    When i position the Relative: X0 Y0
    Absolute reads: X-1.25 Y-2.5
    This is sitting at Work Orgin (prg 0)
    Therfore it is always off by x1.25" and y2.5"
    I am homing my m/c constantly (any alarm, lotsof overtravel) any time reset button is hit
    I have been using the Machine position...and am just about to try the G92 in my MDI
    I hope i have conveyed this info clearly...I am still shocked about this Machining community, its a beautiful thing, and i hope to contribute as much as I take.....THANK YOU ALL!!
    Nov 2007
    canada
    Unhappy
    sO... I have tried the G92 X0 Y0 in MDI, (sitting tool over work datum)
    What A neat trick (thanx Huflungdung), it acually set my Absolute positioning to Zero (wich currently matched my Relative position)
    Unfortunatly, my program did already have G92 X4.319 Y9.674 Z0 (I am editing an existing program to better understand fanuc)
    When I ran into my G0 X0 Y0 (line preceeding G92), I way overtraveled my -Y axis.
    sO I removed that line (G92)...jogged to wrk/datum, executed G92 X0 Y0 in MDI and had same results O.T -Y @ G0 X0 Y0.
  • Page 1 of 3 123 LastLast
    1. Replies: 16
      Last Post: 10-10-2010, 08:02 PM
    2. Setting Tool and Work Offsets
      By Donkey Hotey in forum Haas Lathes
      Last Post: 08-31-2009, 10:42 PM
    3. Replies: 0
      Last Post: 03-03-2006, 07:50 PM
    4. Replies: 1
      Last Post: 10-30-2005, 03:38 PM
    5. Setting Work & Tool offsets
      By Shizzlemah in forum Fadal
      Last Post: 04-16-2005, 01:04 PM
