hi i have a horizontal milling machine FANUC controller OM with rotary table the table is B axis but the G code 107 for cylendrical interpolation is not working, because it's optional and the manufacturer disable it from the controller. the table is rotating just to a certain angle as the operator specifys in the program, i mean the table is not continously rotating to make a cylendrical interpolation operation , so i am thinking if there are any way to adjust the table movement, maybe change some parameters or do some mechanical adjustments or both. the point is i want the G CODE 107 WORKING. note: when i write a G107 in a program, alarm occurs says G code not supported are there any way to make G107 works ? thank you, |
| thnx |
| pulse generators and handle are the same thing.I have 3 horizontals,one is a mori-seiki sh-50 with a fanuc 18.It has a 1 degree table and cannot be rotated with the handle.I also have 2 matsuura hplus 300 with fanuc 30i control.they have a full 4th axis,i can rotate the table by using the handle.that is a simple way of checking to see if you have a full 4th axis.I would never buy another machine without that option.believe me it is worth the 20 or 30 thousand dollars extra. |
| HS1 horizontal mill with auxillary axis alarm | teal854t | Haas Mills | 2 | 04-18-2009 12:47 PM |
| OKK horizontal cnc mill HMA460 | bum1033 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 05-20-2008 08:18 PM |
| Horizontal Mill Management | Metalman97415 | General Metalwork Discussion | 1 | 08-15-2007 06:11 PM |
| horizontal mill made by Tree | PETE1968 | General Metal Working Machines | 6 | 02-22-2007 07:27 AM |
| Help with Horizontal Mill Programming | MAX RPM | Mechanical Calculations/Engineering Design | 8 | 06-20-2006 10:18 PM |
