Results 1 to 6 of 6
Thread: FANUC-6M SPINDLE ORIENTATION
    Jan 2007
    INDIA
    HELLO FRIENDS,
    WE HAVE ONE HITACHI SEIKI WITH FANUC 6M CONTROLLER.
    THE PROBLEM IS WHEN WE GIVE M19 COMMAND THE SPIDLE IS COMMING TO ORIENTATION POSITION BUT AGAIN IT STARTS TO ROTATE CONTINUOUSLY. THE ORIENTATION PCB SETTING IS DISTURBED
    THE MAIN BOARD NO IS A20B-1001-O120
    THE ORIENTATION PCB NO IS A20B-0008-003.
    HOW DO I ADJUST THE ORIENTATION PCB.
    THERE ARE 11 POTENTIOMETERS FOR ADJUSTMENTS.
    CAN ANYBODY GIVE ME THEIR INDUVIDUAL VALUES LIKE WHAT K Ohms.
    CAN ANYBODY HELP ME IN GIVING THE SPINDLE DRIVE MANUAL.
    THANKS
    CHANDU
    Registered guhl's Avatar
    Aug 2007
    Ukraine, Sevastopol
    You should tell number of model of spindle amplifier. I have 6M controller on Hitachi Seiki, but there is another spindle amp.
    nothing to say under this line
    Jan 2007
    INDIA
    Here are the details
    Dear Guhl.
    Thanks for responding to my problem.
    The FANUC CONTROLLER IS 6MB.
    THE SPINDLE DRIVE IS DIGITAL AC SPINDLE DRIVE
    NO A20B-1001-O120.
    THE ORIENTATION PCB IS HAVING THE NO A20B-0008-003.
    THANKS AND REGARDS,
    CHANDRU
    Nov 2007
    Croatia
    Dear Chandu
    I have been looking throw my books.
    First look on ur orientation card and are there any led-diodes. There should be led-diode with name IN POSITION. So when u rotate spindle it should turn off and on when spindle pass over orient. position. If it isnt blinking the sensor may be to far from element or it may be broken or the cable is in break.
    So give command M19 and look.
    Aug 2007
    Ukraine, Sevastopol
    Quote Originally Posted by Cole84 View Post
    Dear Chandu
    There are 3 switches, resembling potentiometers, on my orientation card. Each of them forms binary presentation of hexadecimal number, represented on switch surface. Significance of first x 2^0, second x 2^4, third x 2^8. Summary significance is angle of spindle indexing.
    Feb 2007
    MEXICO
    HELLO FORUM.
    I HAVE A VMC HITACHI MACCMATIC 48V WITH FANUC 6M.
    THE CNC IS OK THE MACHINE DONT TURN ON. MAY BE THAT PLC IS OFF.
    CAN SOMEBODY HELP US?
    CAN SOMBODY SEND US THE ELECTRICAL MANUALS HITACHI?
    SOME IDEA?
    THANK YOU
    1. Spindle orientation
      By StampCraft in forum Haas Mills
      Last Post: 11-10-2007, 06:31 PM
    2. Spindle orientation
      By jimecv in forum Daewoo/Doosan
      Last Post: 11-09-2007, 12:25 PM
    3. 16i / 18i Spindle Orientation...
      By Sump Cleaner in forum Fanuc
      Last Post: 09-11-2007, 08:46 AM
    4. Spindle Orientation
      By machinist39 in forum Haas Mills
      Last Post: 05-04-2006, 09:58 PM
