Old 11-09-2007, 05:15 AM
Jonne is on a distinguished road
Questions about Fanuc spindle DC motor
Hello!
Can anyone explain old Fanuc spindle motor system?
It is type "model 12", I think. It's 18,5 KW.
What is driving voltage ( in motor ) on full speed? 100V or 200V?
What is field coil voltage? Adjust controller this
voltage or is it constant? Why there is 12 thyristors,
is half of those for reserve drive? Thyristors use only
half of sini wave, and power is fixed firing moment?
Thanks afterwards everyone...
Old 11-09-2007, 06:32 AM
Dan Fritz is on a distinguished road
I can answer two of your questions. For the motor and controller specifications, you'll have to find the Fanuc documentation. They did publish a "DC Spindle Descriptions" manual for each model, which should have the specs you need.
Fanuc DC spindle controllers use a variable field voltage. There are circuits on the controller board to weaken the field as the motor speed increases. You'll probably notice that the field voltage will be pretty constant until the motor reaches a certain speed (say, 1000 or 1500 rpm), then it begins to ramp down as the speed increases.
The 12 SCRs are because these are 3-phase FULL WAVE amplifiers, just like the Fanuc servo drives. 6 are facing "forward" to control the motor current running in one direction, the other 6 are facing "backward" to control the motor current in reverse. You will probably notice another 2 smaller SCRs and a pair of diodes that are used as a single phase rectifier to control the field current.
The controller board has two feedback circuits, one for current feedback, and the other for a speed (velocity) feedback. The current feedback comes from a coil that's wound around one of the DC armature outputs, which generates a small current proportional to the armature current. The tach provides the speed feedback, and is mounted on the end of the motor shaft. The tach MUST be kept in good order for proper speed control. The tiny brushes last a long time, but you do have to occasionally clean the tach commutator. I like to rotate the motor slowly and use a pencil eraser for this.
Old 11-09-2007, 07:54 AM
Thanks that info, I was thinking that's how it work.
But why field have to weaken when rpm rise? Is there
risk of over heating, or is it for better torque high rpm?
more rpms for spindle motor and spindle bob1112 Mechanical Calculations/Engineering Design 33 02-10-2007 01:01 PM
Running a Fanuc spindle motor Fudd General Metal Working Machines 3 11-11-2006 09:21 AM
Boss spindle motor wiring questions moto21 Bridgeport and Hardinge Mills 11 03-29-2006 10:13 PM
Spindle Motor Questions? Willyb Haas Mills 5 02-08-2006 12:07 AM
Kitamura Spindle Questions nMotion General Metal Working Machines 0 09-17-2004 05:34 PM
