You could try Para 915 bit #7 1xxxxxxx, 200 registerable programs, It may require hardware depending on how much memory you have now.
Al
Is there any way to get around the 63 program max in the 0-M control?
I have lots of small sub's leaving plenty of memory but need more program numbers.
Al
Try 903.5 if Al's wont get you there, This takes you to 125 #'s and in most cases this is the next step up and rearly requires a hardware upgrade
Bluesman
Thanks!
Al's parameter info seems to have worked. Received error 100 until turning off and restarting then had 200 program numbers available. This forum is a great asset to CNC'rs.
Thanks,
Greatly appreciated
