Results 1 to 5 of 5
Thread: Problem with 4th axis feedmoves on Fanuc controller 0i-MC
    rab
    rab is offline
    Registered rab's Avatar
    Jun 2003
    Scotland
    Machine: Dugard Eagle 450XP with Fanuc controller 0i-MC and rotary table
    The rotary table's axis is 'B' although I'd have thought it should be 'A'.
    Anyway, this machine will move its B-axis position via the MDI or in a program in G0 mode but it comes up with the following error when programmed to move the B-axis in G1 mode.
    "5011 Parameter Zero (cut Max)"
    Can anyone help ?
    Thanks,
    Rab
    Rainnea CNC
    Nov 2003
    Indiana
    Quote Originally Posted by rab View Post
    Can anyone help ?
    Thanks,
    Rab
    Rainnea CNC
    I would guess that the parameter that sets your "Max Cutting Feedrate" is set to Zero so when you give it a G1 x... y... F100 your feedrate is above the set max. Is the 5011 the actual parameter or just the alarm # ? I am not sure. In the older controls it is somewhere in the 1100 to 13?? something area.
    Bob
    Registered dcoupar's Avatar
    Mar 2003
    You might check parameter #1430 (max feedrate for each axis). Maybe they set it for A, but not for B? Just a thought.
    Nov 2003
    Indiana
    Quote Originally Posted by dcoupar View Post
    Thats the # I was looking for. I checked at work last night.
    thanks.
    bob
    rab
    rab is offline
    Jun 2003
    Scotland
    Thank you,
    what's the best way to get the user to check and if neccesary change parameter 1430 ?
    thanks
    Rab
    1. RTCP (For Fanuc 18i Controller) five axis machining
      By Ravasaheb in forum CNC Machining Centers
      Last Post: 07-05-2010, 05:26 AM
    2. Fanuc 0i-t controller ref problem
      By rai in forum Fanuc
      Last Post: 06-09-2007, 02:33 AM
    3. Replies: 10
      Last Post: 06-01-2007, 05:52 PM
    4. Fanuc 0i-MC controller Spindle Problem
      By PJ Engineering in forum Fanuc
      Last Post: 05-18-2007, 11:01 AM
    5. fanuc axis drive problem
      By turbo bob in forum Fanuc
      Last Post: 10-30-2006, 05:10 PM
