Old 11-06-2007, 09:10 PM
bigalow is on a distinguished road
Fanuc 18T positioning
We have an OD grinder that has 3axis. The 3rd axis is the Work spindle or chuck. Uses an actual axes motor and not a spindle motor. Machine can be in either pos mode(eliptical grinding) or spindle(rotary) mode.(M3 M4 Sxxxx
I need to stop the 3rd axes in a certain position to load a part. M19 is not provided from the OEM-Hellenberger. In position mode the axes will eventually hit a Soft Overtravel.
1) I could use a prox and tie it into the skip function with a little macro.Looking for something better
2). Is there a way to reset the pos buffer every rev in pos mode Or
any other idea's that might be fun??? Thanks
18i c-axes positioning bigalow Fanuc 0 11-06-2007 08:57 PM
*** Positioning Problem *** baran3 CNCzone Club House 0 01-26-2007 07:49 PM
DRO positioning is Wrong.How to fix? GisMo Machines running Mach Software 5 10-15-2006 07:20 AM
Fanuc O-M positioning 723 General Metal Working Machines 8 07-30-2004 08:09 PM
photomicroprocessors for positioning turmite General Electronics Discussion 0 06-24-2004 11:37 AM
