Old 11-01-2007, 09:18 PM
DocHod is on a distinguished road
G83/G87 parameters
Hi all I have a question about the parameters more for the G87 pertaining to how far the drill will stop short in the peck drill cycle , off the top of my head parameter #5114 is for the G83 peck cycle to stop short of the last drill depth in the cycle and I have it set at 1000 which is actually .100 is there a parameter to set so the G87 cycle will stop short that distance , right now it stops short .200 and I would like to tighten it up by .100 , this is a Doosan SLY machine with a Fanuc 18i controller. We use the G87 cycle for drilling holes on the O.D. of the part with live tooling . I have a hunch that the parameter used for the G83 cycle is shared with the G87 maybe ? Any help I would thank you all .
Old 11-04-2007, 05:58 AM
cnc-king's Avatar
cnc-king is on a distinguished road
you have to remember that the X axis on the lathe is diametrical not radial so the machine actually doubles the value in parameter #5114 for all X axis work i had the same problem when i first started using the live tooling. i usually program an R value which the machine reads as incremental.
If you can ENVISION it I can make it
Old 11-04-2007, 01:54 PM
thanks King , it does make scence.
OKK Parameters lost!!!! Fidelity_Mold General Metal Working Machines 2 08-01-2007 02:20 PM
parameters for G71 harrascustom G-Code Programing 0 04-09-2007 10:06 AM
Help Need YAM CK2 Parameters bertcnc General Metal Working Machines 2 11-13-2006 03:12 PM
parameters mikeh78 Haas Mills 7 05-02-2006 09:20 PM
Parameters Vince.P Machine Problems, Solutions , Wireless DNC, serial port 3 04-27-2005 07:06 PM
