Fanuc 6T 607 PC alarm and more
Results 1 to 12 of 12
Thread: Fanuc 6T 607 PC alarm and more
    Oct 2007
    United States of America
    Default Fanuc 6T 607 PC alarm and more
    Machine has been not operated for a while. Trying to get going and have:
    210 +X ot
    211 -X ot
    220 +z ot
    221 -z ot
    607 pc
    Machine control is not completely up, no hydraulics, no spindle. I don't think I'm getting power to the whole machine. Still looking for the wiring diagram. thanks Phil
    Dec 2003
    When you get simultaneous OT it usually indicates no 24v feeding the switches, Check the power supply output and check the status lights on the Input Unit, this is the small board with a relay on it that monitors the power up.
    Oct 2007
    That is what I was looking at. This power supply has outputs EON, EOF and FA and FB? It was shorting out (red alarm light) and had this board and the one on the door worked on. The alarm went away, but I could have the door interlock wires possibly misplaced. thanks
    Apr 2006
    What was the part number of the board on the door?
    If it was your IO board you might check the jumpers.
    Is the green LED on, on the IO board?
    Nov 2006
    Scotland
    Sounds like something is pulling the 24v down.Then you get what Al says.
    Mark.
    Apr 2006
    Please note the 607 alarm is a data transfer alarm between the IO board and the front panel board. If the jumpers are set wrong on the IO board this alarm is generated.
    The connectors not hooked up correctly to the IO board will cause this alarm
    The loss of 24volts to the overtravel switches will not cause this alarm.
  7. #7
    Dec 2003
    Quote Originally Posted by cncdiag View Post
    But it will usually cause the OT alarms.
    Oct 2007
    Back looking at this machine. The part number on the board on the door is
    A20B-008-054-01A and yes the green light does come on. I've had this board repaired by a local firm. Before being repaired the large power supply board in the cabinet (part no. A20B-1000-030-06A) was being shorted out by the board on the door. Remove the 24v lead to the door and the short would go away.
  9. #9
    Oct 2007
    We received our reprint wiring diagram from Mazak and from what I can figure out it seems we are not getting the 24v from the "NC Control Device". This would be wires NFA and NFB. This latter show up on the TB10 as NFA and NFB, but then go to TB7 and TB8 where they change to NCAL and +24N.
  10. #10
    Apr 2006
    The A20B-0008-0540 board, there is a jumper, is it set to F 1 or 2.
    How many IO boards do you have?
  11. #11
    Oct 2007
    I believe there is only one output board and on the A20B-0008-0540 the jumper is set to F. thanks
  12. #12
    Oct 2007
    Now alarms are on/off for no apparent reason. Servo alarms will come on and the n go right back off. Might go to just overtravel in x+ and z+, then all four directions at once. Pretty much the 607 alarm stays on all the time.
