Hi! our john ford St60B machine is giving NC alarm 510 (overtravel X+)when it zero returns. system is : fanuc 0M any help. Last edited by hell_pk; 10-25-2007 at 07:46 AM. Reason: more info added |
| The P Can while powering up tells the NC to ignore soft limits that are set in parameters. This allows the machine to make it to limit switch and set zero position. If you are overtraveling at this point you should look at the limit switch and ensure it is functioning properly. Bob |
Param. 65 bit#3 befor a reference position is made,the stored stroke limit is checked(0)/is not checked(1) Param. 700 to 703 First stored stroke limit in the positive direction on each axis Param. 704 to 707 First stored stroke limit in the negative direction on each axis |
Limit switch for x-axix was ok.its wire connection with the T002D card in electrical cabinet was broken somewhere in between.when corrected machine was referenced uning CAN & P combibation and its working now. thanks all |
| Amp Alarm | bbrreid | General Electronics Discussion | 4 | 02-29-2012 05:13 PM |
| Alarm 103...need help?! | JMFabrications | Haas Mills | 10 | 09-28-2007 06:45 PM |
| 401 and 420 alarm | lockmachinist | Fanuc | 1 | 09-20-2007 09:24 PM |
| 205 p/s alarm | bink | Fanuc | 0 | 12-08-2006 09:04 PM |
| Alarm 971 NMI | wanchai101 | Forum Questions or Problems | 0 | 04-24-2006 04:00 AM |
