Hi.
I'm having problems with the wear compensation in my Nakamura Super NTJ. The wear compensation works fine in the lower turret, but in the upper turret the machine ignores the wear compensation.
This only occurs when I run the machine in "MEMORY" mode. So if I run the machine in "MDI", it works.
Has anyone had a similar problem with their machines? Is it some sort of code that makes the machine ignore the wear compensation or is my controller faulty?
Thank you for your help.
/Oskar
LinkBack URL
About LinkBacks
