Old 10-11-2007, 02:54 PM
alikatcraig is on a distinguished road
Fanuc OT memory problems
Can anyone out there help me on this one?
I have a Fanuc OT controlling a Yang ML-5 lathe. We had various memory related messages and then after following the flow chart in the manual we had to re-enter all the parameters. Did this, but noticed that the memory was way down on what it had been, and one program we had just run would no longer fit into the CNC. I know Fanuc used to do floppy drives to expand the memory, and I think some sort of card (the machine is 10 yrs old), but wonder whether there are any more up to date (and cheaper) memory upgrades available without going to Fanuc for a new board? HELP PLEASE!
Al
Old 10-16-2007, 02:32 PM
GPena is on a distinguished road
Your problem is in the options located at parameters 900's. I think that what you did is that you loaded the parameters from the data sheet and sometimes they do no correspond with what the factory (YAM) usually load. Send me the 900's par. contents and I will see if the memory can be upgraded using parameters.
GP.
Old 10-16-2007, 02:51 PM
Al_The_Man's Avatar
Check the 901 bits, usually the 0 was often supplied with 80m, to increase by parameter above that usually requires extra HW.
80m is bit #2. #3 is 40m #4 is 20m.
Old 10-17-2007, 10:54 AM
900 00101000
901 11000000
902 00000100
903 0
904 0
905 00000001
906-10 0
911 00001000
912-16 0
917 00000010
918-99 0
Old 10-17-2007, 11:02 AM
Al_The_Man's Avatar
Your 901 para. show no memory allocation.
You can start at #4 (xxxx1xxxx) and progress through to bit 2.
You could also try #1 if you get to bit #2 and it still seems short.
Only one on at a time.
If you do not have the HW on board, you will get an error message.
Old 10-17-2007, 11:22 AM
As Al explains, that is the way to do it. If your machine had this memory before, I am sure you will get the memory as before doing this. I will suggest that you do a backup of parameters including 900's for future requierements.
GP.
Old 10-17-2007, 12:45 PM
Al - can you clarify your bit order? Is big endian or little endian?? Are you numbering from zero or 1?
Many thanks
Al
Old 10-17-2007, 02:50 PM
Al_The_Man's Avatar
Bits go 0 to 7 from right to left 76543210.
Old 10-17-2007, 07:49 PM
Thanks Al. I will let you know how we get on.
Al
Fanuc 15m Memory rugbyal Fanuc 2 03-03-2008 06:15 PM
Fanuc OM Memory Davidimurray Fanuc 11 11-27-2007 09:02 AM
Increasing Memory in Fanuc 18? jdocmm Fanuc 12 06-06-2007 11:36 PM
Fanuc 0 M memory matic Fanuc 10 05-27-2007 12:33 PM
Memory problems fanuc 3tc R.thayer Fanuc 10 01-29-2007 09:27 AM
