Results 1 to 4 of 4
Thread: Fanuc servo shaft taper angle?
    Feb 2007
    Finland
    Hello again!
    Anyone knows what is taper angle on this Fanuc servo:
    I can measure it with my Bridgeport, but if anyone know...
    Sep 2005
    I believe that all Fanuc motors with a tapered shaft have a taper of 1:10.
    I'm not sure if that's 1(diameter) to 10(length) or 1(radius) to 10(length), but a simple measurement will reveal this. The only diagram I could find online seemed to imply it was 1(radius) to 10(length), but the diagram was not properly dimensioned, so there is some doubt about this.
    Mar 2008
    I do not know if it is 1:10. But 1:10 means 1mm increase in 10 mm length.
    PMT
    PMT is offline
    Mar 2004
    Wisconsin
    My i series motors are 1 dia. : 10 length
  1. DIY Large Bore Hollow-shaft servo motor
    By Eric R. in forum Linear and Rotary Motion
    Last Post: 01-27-2007, 09:19 AM
  2. Hollow Shaft Servo Motor
    By Eric R. in forum Open Source CNC Machine Designs
    Last Post: 01-11-2007, 02:01 PM
  3. Replies: 3
    Last Post: 01-04-2007, 08:50 AM
  4. taper threading using G76 on Fanuc OT
    By sinha_nsit in forum Fanuc
    Last Post: 03-23-2006, 05:31 AM
  5. Fanuc AC Servo Help
    By Babar in forum Servo Motors and Drives
    Last Post: 02-14-2006, 01:34 PM
