Old 09-26-2007, 02:13 PM
shupej is on a distinguished road
Fanuc 11T Soft limit troubles on Slant-1
I am having trouble overriding the software limits of the machine to drive the X axis to a normal position. The X axis is nowhere near the physical limit of the slide. I think the batteries were almost if not completely dead in this machine when I started working on it and had some success with sending a program and doing some manual machining but upon restart of the machine this morning I was able to zero the Z slide fine but the X slide would only move @ an inch off the center of the lathe. The machine cordnance says about an inch on the display for the X slide also. Any help would be appreciated, thanks
Old 09-26-2007, 02:45 PM
Jarwalcot's Avatar
Jarwalcot is on a distinguished road
Position both Z and X middle of their strokes... Power down the machine... Prior to turning on the control, hold in the "P" & "Can" keys and keep them pressed until the control powers up all the way. Now do a Zero Return...
JR Walcott
Georgia Machine Tool Resources, LLC
Old 09-26-2007, 04:30 PM
Thank you for the response.
Fanuc 6T RS232 Troubles Bent82 Fanuc 6 02-06-2007 12:57 PM
fanuc 0m-B troubles sammer003 Machine Problems, Solutions , Wireless DNC, serial port 2 01-25-2007 05:32 AM
lookin for teck soft to fanuc ot mill post stuby Post Processor Files 0 01-15-2007 07:55 PM
Slant 3/ Fanuc 11te Rs232 Info??????? metlshpr Fanuc 6 12-30-2006 05:28 PM
Fanuc OM soft limits reset? CNC Biker Fanuc 4 04-25-2006 09:33 PM
