Results 1 to 8 of 8
Thread: Fanuc 6M Error 086
    Sep 2007
    Sri Lanka
    Exclamation Fanuc 6M Error 086
    Hi all,
    Im getting 086 RS232 error from the Fanuc 6M in AMADA Turret 224,
    I tried to solve this by changing burd rates and othr parameter settings .but i got same error 086 i couldnt change the DB25 to DB25 cable in my test.
    how can i solve this pls help.
    Thanks & rgds
    Chinthaka
    Aug 2005
    Thailand
    Hi
    I have 6M on my Milling.
    This alarm happen when you tranfer data to machine?
    I think Error 086 is cable error.
    Are your cable use to tranfer the data to Machine before?
    Check cable first.
    buad rate 4800 will be OK
    Registered guhl's Avatar
    Aug 2007
    Ukraine, Sevastopol
    Good day.
    Manual says: "The signal level of 232C interface was incorrect". Did You check the voltage level of input or output data? Levels are: 1=-3--..-10V, 0=+3..+10V.
    Aug 2007
    Ukraine, Sevastopol
    By the way, check the digital earth wire.
    Sep 2005
    Alarm 086 happens when either pin #6 or pin #8 on the Fanuc's serial plug is not held "high". Usually, this is solved by jumpering pins 6, 8, and 20 together on the Fanuc side of your cable. An alternate method is to tie pins 6 and 8 on the Fanuc side with the DTR (ready) signal on the other end of the cable. DTR is pin 20 on a 25-pin plug, or pin 4 on a 9-pin plug. This cable works for all Fanucs:
    25-pin Fanuc side -------------9-pin PC side
    pin 2 -------------------------- pin 2
    pin 3 -------------------------- pin 3
    pin 5 -------------------------- pin 7
    pin 7 -------------------------- pin 5
    pin 6 -----
    pin 8 ----- <-- jumper these 3 together
    pin 20 ----
    Another cable configuration is:
    pins 6 and 8 ------------------- pin 4
    Sep 2007
    Sri Lanka
    Thumbs up
    Quote Originally Posted by CBMach View Post
    Hi
    Check cable first.
    Thanks All ,
    All of u ar very helpful.
    Best Regds
    Chinthaka
    Registered acerocket's Avatar
    Jun 2006
    I am also having problems with an 086 P/S alarm on a Fanuc OT machine. How do you cross the pins and jumper the others? Is there a software solution in the computer or do I have to physically wire between the plugs. I am using a DB25 plug at the machine with a USB port on the computer.
    Aug 2007
    Ukraine, Sevastopol
    Quote Originally Posted by acerocket View Post
    You have to possess the USB/RS232 converter to connect the machine and computer. Usually the COM port on the computer is been utilizing for this purpose. It is easier, to my mind.
    nothing to say under this line
    1. Fanuc 5T ERROR 20
      By alduns in forum G-Code Programing
      Last Post: 02-02-2009, 06:15 PM
    2. Fanuc Error 449
      By dhiruj in forum Fanuc
      Last Post: 01-04-2009, 01:18 PM
    3. Help! Fanuc OT error.
      By ua6lfj in forum Fanuc
      Last Post: 09-16-2007, 01:02 PM
    4. Replies: 4
      Last Post: 06-29-2007, 12:38 PM
    5. Fanuc 6MB Error LED
      By tsalpha in forum Fanuc
      Last Post: 01-05-2007, 09:51 AM
