Old 09-20-2007, 10:22 AM
Crashmaster's Avatar
Crashmaster is on a distinguished road
Question How to activate part timer on 10t?
Does anybody know how to enable the part/program timer on a Fanuc 10t?
I am pretty sure it's possible on this control, but the section in my manual is missing for that, figures...
Old 09-20-2007, 11:07 AM
RRL RRL is offline
RRL is on a distinguished road
Crashmaster,
The only parameters I could find in my books related to timers are:
0100 Timer 1 (Accumulated power on hour)
0101 Timer 2 (Accumulated automatic operation hour)
0102 Timer 3 (Accumulated automatic operation hour)
The above are as stated in Fanuc manual B-54815E/06
I checked in the operation manual B-54824E/01, but it did not give any good info at all.
Sorry, but this is all I could find.
RRL
Old 09-20-2007, 11:13 AM
Thanks for looking. I could have sword that there was a part timer for this control.
Old 09-20-2007, 12:19 PM
cncdiag is on a distinguished road
Run/Hour Display is parameter 9106 bit 5 should be a 1
Old 09-20-2007, 12:53 PM
RRL RRL is offline
I never thought that it would be an option parameter!
Good point, though my list just says "clock".
I'd give it a try!
RRL
Old 09-20-2007, 12:58 PM
OK, I found that parameter line. This is the first time I am attempting to change a parameter. I went to change bit 5 from 0 to 1 and it said "Write Protect." Am I looking past something obvious?
Old 09-20-2007, 01:08 PM
DryRun is on a distinguished road
You have to change the 9000 parameters in IPL Mode
if you mess up will need to reload all parameters
what is 9106 right now?
need to convert it to hex and enter it in option7 in ipl mode
Power on while pressing buttons - and . then type 99 for options
just press input in the ones you are not changing
when you get to option 7 type in the new hex number
i would back up all your paramters first
Old 09-20-2007, 01:12 PM
Well damn, maybe this isn't worth the trouble. I don't know what IPL is. And how would I go about backing up my parameters. 9106 now is
0 1 0 0 0 0 0 0
Old 09-20-2007, 01:14 PM
phx phx is offline
phx is on a distinguished road
hi there
this param. is called cycle running time, to change u have to set PWE to 1 first
(Parameter write enabled) , find under offset settings
when ready set to zero back
gl
Old 09-20-2007, 01:41 PM
Ok, I set PWE to 1, but when i tried to change para 9106 bit 5 to 1, now instead of saying write protect, it says parameter locked. Any suggestions?
  #11   Ban this user!
Old 09-20-2007, 02:19 PM
OK here is what you need to do
power down machine
wait 30 seconds
power machine back on holding down - and . keys
at the screen you see type 99 input
then just press input until you get to option7
at option7 type in 60 input
then just keep pressing input until the options are no longer listed
then at main screen press 6 input
control will reboot
on your settings page you will see the timers listed there
  #12   Ban this user!
Old 09-20-2007, 02:32 PM
Ok, I will give that a try. A few questions though. Maybe I didn't explain myself enough. I am looking for a timer that will let me know how long a program runs for. And if at all possible, have this timer show up on my program check screen. If this is not possible and I have to look on my settings page to find how long my program was running for, thats just as good.
OKUMA LB 15 OSP5020L How do I activate foot pedals? duane999 Okuma 4 11-13-2007 08:32 AM
V21 first timer mmachining BobCad-Cam 12 07-10-2007 05:36 AM
First timer jpitty DIY-CNC Router Table Machines 2 02-20-2007 10:38 PM
Timer for fans? Brian Kidd General Electronics Discussion 4 03-05-2006 09:52 PM
Timer.fil How much is to much ? murphy625 CamSoft Products 10 04-04-2005 03:32 PM
