Old 08-29-2007, 04:45 AM
jlong58 is on a distinguished road
fanuc 15-m screen saver?
Hi;
I'm running a Toyoda F550A machining center with a Fanuc 15-M controller. Every couple of minutes the display screen goes blank and I have to hit one of the buttons to bring it back up. I assume this is a screen saver mode, but I haven't been able to find any info on how to adjust or disable it. Can anyone shed some light on it for me?
Old 08-29-2007, 09:51 AM
Bbmachinerepair is on a distinguished road
How to fix Fanuc 15M Screen Saver.
jlong58 -
You need to change the nc parameter #16 to a 0. This parameter is the "Screen Saver Start Time" and if it has a value of 5, that equals 5 minutes. Changing the parameter to 0 will disable the screen saver.
Good Luck.
Old 08-30-2007, 02:37 PM
Thanks for the reply. I checked parameter 16 and it already appears to be set at 0. I was going to try to put a value in to see if it acted differently, but I couldn't figure out how to enable PWE. This is the first time I have tried to change a parameter on this controller. I don't have a manual for it, so I am somewhat in the dark.
Old 09-06-2007, 05:11 PM
Tonester is on a distinguished road
pwe
PWE Parameter Write Enable can be set in MDI Manual data input mode or in emergency stop. If you have an operators panel, hit the offset button until PWE is at the top of the page. then set it to 1. You should pop up an error code " PWE enabled". Then change the parameter you want to try.
Old 09-08-2007, 09:41 PM
cnc-king's Avatar
cnc-king is on a distinguished road
try parameter 3123
If you can ENVISION it I can make it
Homemade Screen Printer/Silk Screen Sbthomas13 Machine Created Art 20 02-13-2009 06:35 PM
Oxy Acetylene gas saver - pilot light zcases Welding, Brazing, Soldering, Sealing 8 02-25-2007 10:31 AM
Fanuc 0-M Screen Help betopuz Fanuc 3 01-24-2007 03:49 AM
Fanuc 3M Blank Screen nastek Fanuc 0 10-31-2006 07:56 AM
21i screen saver? bric2000 Fanuc 2 05-14-2006 03:31 PM
