Parameter 1010 will be for your # of axises. Change to 3. I believe there are others you have to change but I don't have my list with me right now. I'll try to post them tomorrow or you could always call FANUC 1-888-FANUC-US (1888-326-8287) EXT 2.
Im working on a Kitamura horzontal maching center. I belive I have a bad cable from the B axis drive to the endcoder. The machine is in alarm. Dose anyone know what parameters to turn off to shut off the B axis and get this machine out of alarm. I need to move the Z axis forward to gain axcess to the B axis motor and endcoder conection.
Ours has a a 4th axis enable on the operators panel / alarm section. We just turn it off there
Parameter
7 6 5 4 3 2 1 0
012 RMVx
Setting entry is acceptable.
[Data type] Bit axis
RMVx Releasing the alignment of the control axis for each axis
0: Not released
1: Released
NOTE RMVx is valid when the bit7 (RMBx) in parameter 1005 is 1.
7 6 5 4 3 2 1 0
1005 RMBx MCCx
RMBx Releasing the alignment of the control axis for each axis (signal input and setting input)
0: Invalid
1: Valid
MCCx When an axis is released from control, control for the MCC signal for the corresponding servo amplifier is
0: Disabled; 1: Enabled
