Old 08-10-2007, 03:13 PM
ebigfoot2 is on a distinguished road
G68 Coordinate Rotation System
Does a G68 coordinate rotation system stay active if one gets out of a main program and enters a new subroutine? In addition, can G54-G59 be used before the G68 and will the G54-G59 work piece coordinate system reactivate after G69 is commanded?
Thanks.
Old 08-10-2007, 10:09 PM
bob in windsor is on a distinguished road
Yes, g68 will stay on until you cancel it whether you go in and out of subroutines.You can call g54, g55 before you call the rotation command.
G90 G43 G55 H2 Z6
S1000M3
G68 X0Y0R90
X12Y15
Z0
M98 P3 L2
G0Z6
G69
M30
I don't know if your control defaults back to G54 at m30 or reset.If not you need to put it in before the m30 line or you will still be in G55.You can also rotate the coordinates in a sub, say if you wanted to cut angled slot and you knew the center point you wanted to start at.
G91
G68R45
G1 G41Y-.5D1 F40
X5
G3X0Y1R.5
G1X-5
G3X0Y-1R.5
G1G40Y.5
G90
G69
M99
Old 08-13-2007, 07:33 AM
Thanks Bob in windsor.
coordinate system kiethnt G-Code Programing 6 04-26-2007 07:46 AM
Using 3d Coordinate Conversion On A Vf4 renglish Haas Mills 3 02-02-2007 11:04 AM
Coordinate system problems R.thayer LinuxCNC (formerly EMC2) 0 11-19-2006 02:36 PM
coverting from Right-hand to left-hand coordinate system eltonr General CAM Discussion 6 10-14-2004 08:40 PM
User coordinate system? HuFlungDung OneCNC 5 04-18-2003 09:26 PM
