Old 08-05-2007, 02:22 PM
John3 is on a distinguished road
Fanuc 0T Work offsets
Hello,
Does anyone know how to set the work offsets (X & Z) via program on a Fanuc 0T control.
I can get to these values via "MDI - Offset Screen - Work offsets" to manually enter values, but I'd like to set these via program control.
The standard G54 work offset gives a P/S alarm.... command not valid.
Is there a way to load this with the G10 Parameter command? I don't know how.
Thanks,
John
Old 08-05-2007, 02:33 PM
Al_The_Man's Avatar
You need to check if you have P900 #1=1 G10, You should have P910 #1=1, this is the G54 ~ offsets.
Old 08-05-2007, 02:55 PM
Al,
On my machine P900 = 0011 1010 and P910= 1001 1000.
The half-assed manual that I have doesn't show parameters in this range, it stops at 799 and resumes at 1000.
I did understand the "G10 in your last reply.
John
Old 08-05-2007, 03:19 PM
Al_The_Man's Avatar
The parameters are numbered from 0 from right to left, so for G10 your P900 should be xxxxxx1x
and the G54 should be xxxxxx1x.
You will not see the 900 option parameters in any book, as these are the one Fanuc charge you for.
Old 08-05-2007, 03:33 PM
Al,
Again, your quick responses are much appreciated!!!
I just tried setting P910 from 1001 1000 to 1001 1010 and got scary results.
After rebooting and verifying that the parameter did change, I tried an MDI G54 and still got a P/S 010 alarm.
Also, with that new bit set I could not perform a Zero-Return on the C-Axis of this machine.
I reset P910 bit 1 back to zero, rebooted and the C-Axis zero-return worked once again.
Who is being stupid, me or my machine?
John
Old 08-05-2007, 05:51 PM
Anybody.....
Looking through the small amount of documentation that I have for the 0T, it seems to imply that G54 offsets were only supported on the 0M version and not the 0T version.
If that's the case, how are the Work Offsets entered other than on the MDI Offset Page (via program).
John
Old 08-05-2007, 09:23 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Originally Posted by John3 View Post
Anybody.....
John
There should be an Offset Titled "Work Shift". This is the one you should be using on a Lathe. The Fanuc 0M is a Mill Control. I haven't used anything other than "Work Shift". I was told not to use G54-G59 on a Lathe LOL.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 10-16-2009, 11:21 PM
saul is on a distinguished road
hi mr "Al_The_Man" i have a fanuc 0t and can`t make atc run whit a program can you help me
in manual mode run goog the two turrets but in auto mode not go
multiple work offsets rbest27 Surfcam 2 01-25-2007 03:02 AM
how do you set G54 thru G59 work offsets? Barney Fanuc 10 01-07-2007 03:02 PM
Bridgeport VMC 500 XP1 - Work Offsets cadcamjohn Bridgeport and Hardinge Mills 3 05-03-2006 04:31 PM
work offsets 5axisdan Mazak, Mitsubishi, Mazatrol 0 07-04-2005 10:17 AM
Work Offsets new2cnc Mastercam 3 04-30-2005 10:04 AM
