Old 07-19-2007, 10:51 AM
rai rai is offline
rai is on a distinguished road
Fanuc Oi-TA LCD problem
I have a Fanuc Oi-TA cnc it's Lcd display is not working properly. Sometimes it's get distortion wave & I could not see the display. even sometimes it's display shifts horizontally. I tried to adust it by switch ( Located on the back of display ) could not succeed. what I have found is that whenever I try to remove the cable (Cable # 2042-T201, L=050 ) between LCD display to it's pcb ( A16B-2300-0201/04B) then I reinsert the cable It solve my problem them it will work fine for 1 to 2 days only. Please tell me what is the problem so that I could solve my problem.
Is it possible to switch over LCD to CRT screen?
I also have same system Oi-Ta with crt display.
Old 09-28-2010, 12:44 AM
NZ_Jase is on a distinguished road
Hi, did you solve this problem? I have something similar where the display is copied 4 times over itself, so it looks like columns down the display, with a whole bunch of flickering. I can't cure it, and have already swapped out the graphics module in the psu/io unit. Do I order a new LCD panel or a new fanuc pcb that mounts to the back of it? Cheers, Jason
Old 09-28-2010, 08:22 AM
memoryman is on a distinguished road
could it be a grounding problem? Check this.
Old 09-28-2010, 11:14 AM
rai rai is offline
It was a LCD problem, after replacing old LCD with new LCD the problem got eliminated.
Old 09-28-2010, 02:53 PM
Cheers. My control is the machining centre version of yours. Oi-m. The LCD and monitor control PCB will be very similar. I found a new LCD that is a direct replacement but with better specs (viewing angle, glare, contrast ratio) direct from Sharp. Should be here in a few days. Fingers crossed...
I'll check grounding harness, and double-check all the other interconnect wiring again, but I'm pretty sure it will turn out to be a hardware failure, as the machine has been rock solid for years, is well maintained, and is in a nice environment. I haven't used it for a couple of months, and about a minute after powering up the screen image went all garbled and hasn't come right.
There is a Graphics Module in the PSU/IO control that clips in like RAM into a PC mainboard, so that was cheap and easy to change. If it's not cured with the LCD panel things might get a bit more costly as I'll be ringing Fanuc. Unless anyone out there has a spare A16B-2300-0201/04B pcb??
Old 06-16-2011, 08:12 AM
admuthu is on a distinguished road
Hai,
I also face the same problem, the display got scroll. in my case it will stable only 10 to 15 mins only. could you suggest to solve the issue.
Old 01-31-2012, 06:00 AM
ALTAF JANGDA is on a distinguished road
We have CNC Lathe with Fanuc OiTD controller. We have seen a little line at right side of the LCD. Would any body suggest the reason and countermeasure?
Fanuc OT problem Skybrake Fanuc 16 02-09-2007 12:04 AM
Fanuc 6M Problem Mimas Fanuc 3 12-16-2006 06:03 PM
Fanuc 0M problem bauhar Fanuc 6 09-11-2006 10:01 PM
Fanuc 6mb G54 problem... kangarabbit Fanuc 6 05-08-2006 02:35 PM
Fanuc 5 problem jevs Fanuc 3 02-21-2005 07:36 PM
