Old 07-18-2007, 07:56 AM
Kev4966 is on a distinguished road
Fanuc OM B axis rotation
I have a Makino A55 with an OM controller. When rotating the B axis, whether in the program or in MDI, the machine only moves 1/2 of the programmed amount. The CRT however outputs the programmed position, not the actual. Has anyone ever seen this before?
Old 07-19-2007, 07:22 AM
captainasty is on a distinguished road
Smile
Check the ratio setup for the B axis. Different rotatry tables have different pully ratios.
Old 07-19-2007, 08:16 AM
Al_The_Man's Avatar
Sounds like the ratio parameters DMR CMR are out.
Old 07-19-2007, 11:03 AM
Thanks for the information, can you tell which parameter controls this feature, I do not have a parameter manual for this controller?
Old 07-19-2007, 01:30 PM
Al_The_Man's Avatar
If you want to send me a PM with an email add, I can send you the Connection manual which will show how.
Old 10-16-2008, 02:09 AM
cncrepairs is on a distinguished road
B moves half of commanded .
Mirror image may be on ,check led status on top of crt. Cancell mirror by m23or m29.
Shree
cncrepairs@rediffmail.com
A axis continues rotation ? thirty78 G-Code Programing 4 12-13-2006 01:47 PM
Rotation control help on A axis Art Ransom DIY-CNC Router Table Machines 27 09-23-2006 07:04 AM
A Axis Constant Rotation 1ctoolfool Haas Mills 9 09-22-2006 09:57 AM
X axis to A rotation quemast G-Code Programing 6 06-17-2006 08:36 PM
Converting X axis to A rotation quemast GibbsCAM 2 06-09-2006 10:17 AM
