Old 07-16-2007, 01:41 PM
dmcool is on a distinguished road
Fanuc 16T tool nose comp question
Hey guys, i have a quick question. i have a new Nakamura lathe with a 16T console on my shop floor. What i need is a little help with displaying the tool nose comp columns in the geom and the ware pages. i read threw my manual like 4 times and finally found a blurb about it. but i can not seem to find the parameter that i need to change to turn on the tool nose comp option. any help would be appreciated thanks.
Old 07-16-2007, 06:18 PM
John3 is on a distinguished road
This may be a dumb answer, but you turn on cutter comp with G41 (left) or G42 (right) in your part program.
If you are saying that these commands don't work, there is a parameter somewhere that needs to be set to a "1" if your machine has the firmware to support cutter comp.
John
Old 07-16-2007, 11:37 PM
dcoupar's Avatar
Is this a NEW machine? I can't believe they didn't turn on TNR comp. I'd call your dealer.
Old 07-17-2007, 12:38 AM
CNCRim's Avatar
Yeahh G41/G42 should do the trick.
Old 07-23-2007, 11:21 AM
*Registered User*
Bluesman is on a distinguished road
Check 9927.6 in the options to see if it is on, As as far as I knew I thought they all came standard now with auto tool nose comp. I can send you the parrameter manual for the 16iT. Just sedn me a private with an e-mail address. It is toi big a file to post here
Bluesman
tool nose radius comp joe1970 G-Code Programing 8 02-24-2010 09:43 PM
Fanuc 5T Tool Nose Compensation John3 Fanuc 1 07-15-2007 10:58 PM
Tool Nose Radius Fault with Program Josh-PTP Haas Mills 4 06-30-2007 05:03 PM
Tool: Ball Nose definition in BobCad rherman BobCad-Cam 5 09-20-2006 03:48 PM
tool nose comp.? pp-TG General Metalwork Discussion 1 09-19-2006 03:36 PM
