Results 1 to 5 of 5
Thread: Fanuc 21i-T DNC Problem
    May 2006
    Netherlands
    Hi guys,
    I 'am having a problem with DNC on my Collchester Lathe. When i "punch" or "read" i get a alarm number 233 saying "Device Busy". Can someone help me with this.....
    Registered dcoupar's Avatar
    Mar 2003
    233? That's a new one on me...
    How is your cable wired?
    Have you ever communicated with this machine?
    What are your settings for I/O channel, device num, etc?
    Feb 2007
    I've seen the 233 alarm a couple times. It is difficult to explain in writing but there is a setting on the PMC side of the machine that is set. It is called online monitor. I can't remember exactly where it is located but I think it is under the settings softkey on the pmc side. Once you find "online monitor" select not use. It's the only other thing in the control that uses RS-232. Hope this helps.
    Nov 2006
    Bulgaria
    SYSTEM button; [PMC] [>] [MONIT] [ONLINE] [EMG] [INIT] will disconnect PMC
    Set parameter No.24 to 255 and PMC will not occupy the serial port at power on.
    regards,
    May 2006
    Netherlands
    Thanks a lot guys! It's working!
    1. Fanuc OT problem
      By Skybrake in forum Fanuc
      Last Post: 02-09-2007, 01:04 AM
    2. Fanuc 6M Problem
      By Mimas in forum Fanuc
      Last Post: 12-16-2006, 07:03 PM
    3. Fanuc 0M problem
      By bauhar in forum Fanuc
      Last Post: 09-11-2006, 11:01 PM
    4. Fanuc 6mb G54 problem...
      By kangarabbit in forum Fanuc
      Last Post: 05-08-2006, 03:35 PM
    5. Fanuc 5 problem
      By jevs in forum Fanuc
      Last Post: 02-21-2005, 08:36 PM
