Dear all, Unfortunatly, I try to make a PMCbackup on a Fanuc 15 MA. I've a RS232 connection with CNCmast (mitsui seiki). I already went in I/O of PMC but it doesn't work. Please help, thank you |
| Make sure your personal computer is set up ready to receive your PMC Parameter file. Set PWE (parameter write enable) BIT if not already turned ON. Press “E-STOP”. Press “PCPRM” soft key. Press “KEEPRL” soft key. On the MDI keypad in the lower left corner, press the double left arrow key to get the pointer to KeepRelay #18 (K17). Copy the values in K17, if not zero. Set K17 bit 7 to one. (Enter 10000000 and press “INPUT” on MDI keypad.) This permits entry of PC parameters. Press “LEFT ARROW” soft key. Press “RIGHT ARROW” soft key. Press “SYSPRM” soft key. Choose “PG CHANNEL” on screen. Change the zero to one ( by pressing “1” and “INPUT” on the MDI keypad. Press “LEFT ARROW” soft key. Press “I/O” soft key. Press “FDCAS” soft key. Press “OUTPUT” soft key. Press “PARAM” soft key. Press “ADD” soft key. Press “EXEC” soft key. The word “EXECUTING” will flash while uploading. Your control screen will say “OUTPUT COMPLETED. Note: the PMC communicates at 4800 (default) or 9600 Baud . |
| Mori Seiki SL15 dump parmeters & were not backup | john neathery | Machine Problems, Solutions , Wireless DNC, serial port | 2 | 08-08-2007 07:47 AM |
| Cnc Milling Problem (mitsui Seiki- Yasnac Mx1) | le_hungvn | General CNC (Mill and Lathe) Control Software (NC) | 0 | 11-16-2006 01:44 AM |
| Jasnac MX1 Control Help! Mitsui Seiki Cnc Milling. | le_hungvn | General CNC (Mill and Lathe) Control Software (NC) | 0 | 08-30-2005 08:25 AM |
| Fanuc 15MA Time | utengineer04 | Fanuc | 2 | 06-09-2005 02:14 PM |
