Old 07-06-2007, 07:06 AM
Goran P. is on a distinguished road
Fanuc 16i-m Helical Interpolation Problem
I'm having trouble getting my machine to do the helical interpolation, I'm not sure if it is a programming error or the parameter is disabled to do so. This is the code i'm inputing into the machine:
T1
M06 ( 2" MITSUBISHI)
G00 G90 G54 X0. Y0. S700 M03
G43 H1 Z2. M08
Z.1
G01 Z0. F45.
G03 Y.4685 I0. J.2343
Y-.4685 Z-.025 I0. J-.4685 (This is where I get the alarm)
Y.4685 Z-.05 I0. J.4685
Y-.4685 Z-.075 I0. J-.4685
Y.4685 Z-.1 I0. J.4685
Y-.4685 Z-.125 I0. J-.4685
The alarm I am getting is; 021 Illegal Plane Axis Commanded
I'm desparate for some help, Thanks in advance...
Goran P.
Old 07-06-2007, 07:11 AM
Sump Cleaner's Avatar
Sump Cleaner is on a distinguished road
Goran,
Sounds like a parameter issue. For the 16i, set #9930 bit 3 to 1 to enable helical interpolation.
JK
Old 07-06-2007, 07:38 AM
Thanks for reply JK.
However i'm not parameter literate, this is what i have for 9930;
0 1 0 0 0 1 1 1
what should i change it to?
Old 07-06-2007, 08:23 AM
Goran,
Change #9930 to:
0 1 0 0 1 1 1 1
It works like this;
______bit7__bit6__bit5__bit4__ bit3__ bit2__bit1__bit0
9930___0____1____0____0_____1_____1____1____1
JK
Old 07-06-2007, 09:13 AM
JK,
I changed the parameter and the helical interpolation works fine now. Thank you very much for your help.
Goran
Old 07-06-2007, 09:31 AM
No Problem...
JK
Old 07-06-2007, 06:20 PM
Mitsui Seiki's Avatar
Mitsui Seiki is on a distinguished road
Deleted
Old 07-06-2007, 10:56 PM
CNCRim's Avatar
The program don't look right, the program is Y Z and the vector is I J........ It should be K J or vice versa.
Old 07-07-2007, 03:04 AM
It does if you do a circular interpolation with changing Z depths.
Old 07-07-2007, 05:51 AM
ChattaMan is on a distinguished road
Thumbs up Modal
Newtexas2006.....
X0 is modal so there's no need for it in the prog. As he says...it works now.
  #11   Ban this user!
Old 03-26-2009, 03:04 PM
bsamc2000's Avatar
bsamc2000 is on a distinguished road
We just purchased a machine with this same controller. How do I tell if mine have scale and rotation?
  #12   Ban this user!
Old 03-27-2009, 02:41 AM
sinha_nsit is on a distinguished road
G43 H1 Z2. M08
Z.1
G01 Z0. F45.
The program is OK.
The centre of the first arc, however, is not exactly at the mid-point. So, the tool will first go to Y0.4686, and then come back to Y0.4685. This is, of course, only a theoretical issue, with no practical significance. If, however, the "error" is too large (set by a parameter), an alarm condition will be generated.
helical interpolation parameter stude8 Fanuc 25 05-22-2012 01:10 PM
Need Helical Interpolation example for Heidenhain TNC355 soweebee Bridgeport and Hardinge Mills 4 03-14-2012 07:36 AM
Fanuc 11M Helical Interpolation MrMagooo Fanuc 3 11-15-2006 09:58 AM
hHow to smooth a program thats got a loop? (helical interpolation) Darc G-Code Programing 6 08-22-2006 08:47 AM
Helical Interpolation dbcoop11 Bridgeport and Hardinge Mills 4 12-31-2004 10:15 AM
