Old 07-05-2007, 06:22 AM
Dee Bee is on a distinguished road
Ikegai FX25n spindle range shift
Hi All;
Does anyone know the M code to get the high-low clutch on a FX25 to change? I can get it to change using the manual controls but not in a program. A 1500 rpm speed will stay in high when given a 200 rpm command. The spindle will slow down to the commanded speed but, will stay in high range. I need a shift for the torque. I'm thinking an M code for the range shift? The control is a Fanuc 5T Thanks db
Old 07-05-2007, 10:54 AM
Dan Fritz is on a distinguished road
I'm not sure about the Ikegai, but the EIA standard M-codes for gear changes are M40 through M45. If you put one of these M-codes into your program and the Ikegai doesn't use it, the control will just stop on that block with the cycle start light on. You should then be able to reset and try another M-code.
Old 07-07-2007, 02:20 PM
Dan;
I tried M40 to M45 no luck! The cycle start light comes on and stays on till I hit reset. Any other ones you can think of? Thanks db
Old 12-11-2008, 10:37 PM
Paul Pippenger is on a distinguished road
Fx25N
M38 -M39 will change the clutch Clamping
Paul
Ikegai FX20N lathe gridley51 General Metal Working Machines 9 11-17-2007 06:19 PM
Ikegai TV-4 machine M06 not working. Ashu CNC Machining Centers 23 09-26-2007 09:47 AM
Ikegai FX25n spindle range shift Dee Bee General Metal Working Machines 3 07-07-2007 04:35 PM
How much does an Ikegai FT20U weigh? protrxrptr17 General Metal Working Machines 1 12-13-2006 07:39 PM
Spindle speed range or lack of it! creep_pea Bridgeport and Hardinge Mills 7 10-04-2006 04:42 PM
