Hey guys, I am having a little problem with a tool nose radius program on my lathe. The tools radius is .031" Here is the part of the program that is giving me problems. I keep getting a 041 alarm. Thanks for any help....... N1 M98P1 T0101(80 DIAMOND TOOL RADIUS = .031 TOOLNOSE QUADRANT = 3)) G97S800M13 G00X1.4Z.0 G50S2500 G96S600 G99 G01G99X0.F.005 G00Z.1 G00X1.55Z.1 G42X1.45Z.05 G99 G71U.05R.015 G71P100Q200U.03W.01F.005 N100G0X1.0 G01G99Z0.F.005 X1.191,R.03 X1.375Z-.875 Z-1.0 X1.4 N200G0X1.45 G70P100Q200 M98P1 Thanks for any help........ |
| To turn compensation on, the machine must move at least the distance of the nose radius in X and Z. For easy calculations, back away from the start point 0.1 in Z and 0.2 in X. To turn compensation off, we feed the cutter completely off the work and then make a move larger than the nose radius while calling G40. Check your decimal points I see a (,) somewhere in there. Cheers. |
If you got rid of the G42, you could shorten the program by a couple more blocks Last edited by g-codeguy; 07-01-2007 at 01:26 AM. |
| HMMMMM...our Fanucs won't use cutter comp in a canned cycle. I see a couple of issues, Don't forget the tool type settings and tool radius in the geometry screen. It may be a tad longer but you can see the G42 install and cancel G0X1.45Z.05 G71U.05R.015 G71P100Q200U.03W.01F.005 N100G0X1.0 G01Z0. G1X1.137Z0.0 G03X1.1966Z-.0269R.03 "X1.191,R.03(WON'T WORK)" iF IT WAS AT 90 DEG IT WOULD NEED R-.03 G1X1.375Z-.875 Z-1.0 N200X1.45 G0X1.5Z.1 G42X1.45Z.05 G0X1.0 G01Z0. G1X1.137 G03X1.1966Z-.0269R.03 G1X1.375Z-.875 Z-1.0 X1.45 G0G40X1.5Z.1 |
The reason your comp isn't working is one or both of these reasons. 1) Your using a control that is older than 1984. 2) You need to call the TNR Comp in the Canned Cycle or it won't work. Here is an example: % O0086 G0 G40 G97 G99 T0 M5 G28 U0 W0 M9 G50 S2000 M41 M1 N1(REMOVE SKIN/R-FACE/TURN) G28 U0 W0 T0 T101 M8 G96 S475 M3 G0 G42 X3.99 Z.3 G1 Z-1.3 F.01 X4.05 F.015 G0 G40 X4.1 Z.2 G72 P10 Q15 W.005 D400 F.008 N10 G0 G41 Z0 N15 G1 X0 F.004 G0 G40 X4.0 Z.1 G71 P20 Q25 U.02 W.002 D850 F.01 N20 G0 G42 X1.0 G1 Z0 F.0025 X1.325 F.003 G3 X1.375 Z-.025 R.025 F.0025 G1 Z-.75 F.004 X2.75 F.0035 X3.975 Z-.9141 F.0025 G1 Z-1.08 F.004 N25 X4.1 F.0035 G0 G40 Z.1 M9 G28 U0 W0 G97 T0 M1 N2(F-FACE/TURN/U-CUT) G28 U0 W0 T0 T303 M8 G96 S650 M3 G0 G41 X1.5 Z0 G1 X0 F.004 G0 G40 X4.1 Z.1 G70 P20 Q25 G0 G40 Z.1 (U-CUT) G1 X1.3755 Z-.725 F.05 Z-.755 F.004 G4 U1.0 G1 Z-.75 F.006 X2.8 F.003 G0 G40 Z.1 M9 G28 U0 W0 M5 G97 T0 M1 N3(DRILL) G28 U0 W0 T0 T505 M8 G97 S400 M3 G0 X0 Z.25 G1 Z-2.25 F.0072 Z.05 F.2 G0 G40 Z.1 M9 G28 U0 W0 G97 T0 M1 N4(R-BORE ) G28 U0 W0 T0 T707 M8 G96 S400 M3 G0 G40 X.75 Z.1 G71 P40 Q45 U-.02 W.002 D320 F.0075 N40 G0 G41 X1.214 G1 X.814 Z-.1 F.003 Z-1.3 F.005 N45 X.75 G0 G40 Z.1 M9 G28 U0 W0 G97 T0 M1 N5(F-BORE) G28 U0 W0 T0 T707 M8 G96 S550 M3 G0 G40 X.75 Z.1 G70 P40 Q45 G0 G40 Z.1 M9 G28 U0 W0 G97 T0 M30 % BTW: Look at the notes in the Fanuc Manual. It will explain everything.
tobyaxis My problem was I learned on a pre 84 controller and hate reading the manual! Nice detail to know! I still see somthing wrong with. X1.191,R.03 X1.375Z-.875 Should be G03X1.1966Z-.0269R.03 G1X1.375Z-.875 Or it is a new feature with the newer controllers? I do know the alarm number can say one thing and the problem is something else! Dave |
You might want to call Fanuc, or your machine builder. There could be a Parameter setting that needs to be changed.
| try it like this N1 M98P1 T0101(80 DIAMOND TOOL RADIUS = .031 TOOLNOSE QUADRANT = 3)) G97S800M13 G00X1.55Z.1 G71U.05R.015 G71P100Q200U.03W.01F.005 N100G0G42X1.0 G01Z0.F.005 X1.191,R.03 X1.375Z-.875 Z-1.0 X1.4 N200G0G40Z.1 G70P100Q200 M98P1 It helps to get rid of the junk. |
#10
It is used for "blueprint programming" ,A for angle ,C for chamfer. ,R for radius. Oh yeah and I looked at my P1 program for safe indexing and it had G40 and G99 in it........course I wrote it a long time ago and could not remember what all it had in it. Anyhows the last line in the G71 cycle should be GOZ.1 instead of an X dim. |
#11
I had to load the program in a newer controller to see if it really worked. My controller doesn't like the "," in the line. alarms 053 I think it was "to many charactures in line"?! I found the "GOZ.1 instead of an X dim". |
#12
| Hardinge threading code | Pontiff51 | General Metalwork Discussion | 3 | 03-16-2009 11:37 AM |
| Surfcam to fanuc ot lathe (post problem) | ppm620 | Post Processor Files | 6 | 01-21-2007 09:55 PM |
| Hardinge CNC lathe | WJ MARK | General Metal Working Machines | 4 | 09-29-2006 08:29 PM |
| fanuc 11 lathe g-code | bobcor | Fanuc | 3 | 08-20-2006 02:16 PM |
| Hardinge Lathe | jrc347 | General Metal Working Machines | 9 | 12-16-2004 07:34 PM |
