Results 1 to 3 of 3
Thread: Help with integer values
    Jun 2007
    England
    Could someone help me clarify the values to use in canned cycles, eg: G76 Q,R etc, I'm not sure how many places to move the decimal point, and some info on the web appears to conflict
    I'll probably be using both imperial and metric at some stage.
    So, for example, could you give me the integer amounts for the following,
    Metric
    0.05mm
    0.1mm
    0.25mm
    1.0mm
    Inch
    0.005"
    0.01"
    0.025"
    0.10"
    Any help much appreciated
    Registered Sump Cleaner's Avatar
    Dec 2005
    Clarke200,
    When you remove the decimal point for the values, 1 becomes the smallest increment of the machine. For most machines the smallest increment in metric is .001 and in inch is .0001.
    Metric
    0.05mm becomes 50
    0.1mm becomes 100
    0.25mm becomes 250
    1.0mm becomes 1000
    Inch
    0.005" becomes 50
    0.01" becomes 100
    0.025" becomes 250
    0.10" becomes 1000
    Hope this helps you out.
    JK
    Jun 2007
    England
    Thats great,
    Thanks very much
  1. Torque values
    By cncshaper in forum Stepper Motors and Drives
    Last Post: 11-23-2007, 12:17 AM
  2. Inverting values.
    By jymdman in forum Post Processors for MC
    Last Post: 03-11-2007, 02:32 PM
  3. List of L values for G10 L??
    By iMisspell in forum G-Code Programing
    Last Post: 07-30-2006, 11:32 PM
  4. Output values??
    By hop in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 06-07-2006, 06:37 AM
  5. Wizard values can't change?
    By DennisCNC in forum Mach Software (ArtSoft software)
    Last Post: 12-15-2005, 08:30 AM
